Originally posted by Spock but now with pixel-dense cameras like the K3 and later cameras you get better results cropping the images taken with just the lens than with the lens+converter.
I sort of agree with you but it's close. I also think the bigger focus target helps as in the Goshawk above.
Originally posted by UncleVanya What was the underlying lens used?
Originally posted by UncleVanya Are these made on a crop body?
K3III + DA*300 (see EXIF)
Originally posted by dlhawes I'd pick 'em in this order: tamron, kenko, pentax
Originally posted by luftfluss The Pentax TC is pretty obviously the worst performer here.
In tests the other day I'd put the Pentax first, which is why I started my post with the conclusion I did. I suspect that multiple tests under controlled conditions would be needed to pick a winner optically and even then it may not be a clear winner.
