09-13-2021, 10:13 PM - 3 Likes   #1
Teleconverters - Pentax v Kenko v Tamron
I'll start with the conclusion - Better testing would be needed to determine which of these three is the sharpest.
I've had the Tamron-F 1.4x Pz-AF MC4 for a while now and bought the Kenko 1.5x TELEPLUS SHQ a few months ago. These, I am certain, are one and the same re-badged. Both are actually 1.39x magnification.
Last week the Pentax came within my price range and I grabbed one because of the AW and the fact that the camera knows that it's there. It has a magnification a bit over 1.4x but I haven't yet worked it out exactly.
I've done two quick and dirty tests. In the first the Pentax appeared sharper but it was in direct sunlight and the ruler bowed as it heated up so the focus point may have changed between tests. The second test (today) was in bright shade with the ruler allowed to stretch without bowing.
Images from todays test:
PENTAX K-3 Mark III  Photo
09-13-2021, 11:13 PM   #2
Man, those all look pretty good to me. Iíve been vaguely waiting for the Pentax to come up in the right price range but those other options look pretty good, at least in that example.
09-14-2021, 12:09 AM   #3
Although I'm a fan of teleconverters, I only use one when necessary and haven't yet found an appropriate Pentax unit that could justify it's asking price (for what I want).
I'm usually happy with the results from my Kenko 1.5x and seeing these results I'll probably stay that way
Thanks for making the effort to take and publish these results
09-14-2021, 12:40 AM   #4
Des
Des's Avatar
Interesting comparison Craig. I have the Kenko too. If using a tripod with SR off (as I assume your test shots are), the Kenko compares well with the Pentax DA in your test. But for handheld use, the major limitation of a third party TC is that it doesn't pass the effective focal length to the camera and this affects shake reduction.
I would spring for the DA for this alone if it weren't so expensive. Even in the recent ebay sale, it was still $A500. Ouch. That's more than I paid for my 55-300 PLM. The Kenko was about $A150 in mint condition.
09-14-2021, 01:11 AM   #5
QuoteOriginally posted by Des Quote
I'm not sure how much that matters really.
Remember this shot? This is at 275m (300ft) K3 DA*300 Tamron-F TC.
I've scaled it up to 200%. I really wouldn't have expected to see the pupil of a Goshawk at that distance.
On the other hand I do expect benefits of the camera knowing there is a TC fitted.
09-14-2021, 01:31 AM   #6
Des
Des's Avatar
QuoteOriginally posted by alfa75ts Quote
I suppose one way to test it would be with a manual lens and dialling in different focal lengths.
Are you not noticing any improvement in the field with the DA TC? If the optical performance is similar, the difference can only be because the camera knows the effective focal length. And surely that matters because of SR?
09-14-2021, 01:47 AM   #7
To be honest, things vary too much in the field to make direct comparisons. One tiny puff of wind.....
Besides, it's only been a few days.
09-14-2021, 04:11 AM   #8
Spock's Avatar
In my opinion and experience (I've owned F-1.7AF , A-1.4, and DA-1.4 rear converters), teleconverters were useful with film and with early DSLRs but now with pixel-dense cameras like the K3 and later cameras you get better results cropping the images taken with just the lens than with the lens+converter.
Perhaps with stopped down apertures, teleconverters may give better results than cropping, but I usually use long lenses wide open or close to wide open.
09-14-2021, 04:31 AM   #9
GUB
GUB's Avatar
Nice work.
I never use teleconverters because of a long held belief they degrade the image too much . But nowadays struggling for reach with the K-1 I wonder if I need to re-evaluate this.
I am aware that they have a use in macro and have been told that image degradation is less with macro but am not sure about that.
But most people use them for long distance work and I wonder if you were to test at a longer range that you may get a different result?
09-14-2021, 04:45 AM   #10
dlhawes's Avatar
Of the three pics, I'd pick 'em in this order: tamron, kenko, pentax. That's not about sharpness, it's about data loss (contrast, luminosity, texture).
09-14-2021, 06:22 AM - 1 Like   #11
You can also reference the comparisons in this thread, by myself, WildMark and others.
Teleconverter challenge Sigma vs Kenko vs Tamron X1.4 - PentaxForums.com
Also the reviews:
https://www.pentaxforums.com/userreviews/kenko-pz-af-1-5x-teleplus-shq-teleconverter.html
09-14-2021, 08:05 AM - 1 Like   #12
I can't see any differences among your test shots. They all look sharp to me. I've had the Pentax DA 1.4x for about 2 years. The only lens I use it with is the DA*300mm. I see no need to use it on any other lens I have. I am still undecided as to which is best. The 300mm w/teleconverter or the 300mm alone and just crop the image.
09-14-2021, 08:55 AM   #13
The Kenko & Tamron are indeed the same. I actually just compared the Tamron (two of them) vs the Pentax yesterday and couldn't find a difference in quality other than the Pentax is slightly more magnified. The Pentax has the advantage of weather-sealing and it transmits the proper adjusted focal length to the camera so the shake reduction works better. The Kenko/Tamron is full-frame however, and the Pentax is not.
09-14-2021, 09:23 AM   #14
UncleVanya's Avatar
What was the underlying lens used? This may vary with the lens as much as anything.
09-14-2021, 12:25 PM   #15
luftfluss's Avatar
I'm guessing the DA* 300/4 is the primary lens, as the OP has one.
The Pentax TC is pretty obviously the worst performer here.
1.4x, k-mount, kenko, magnification, pentax, pentax lens, pentax v kenko, ruler, slr lens, tc, teleconverter, teleconverters pentax, test, tests, tripod
Two Teleconverters: Kenko P-AF 2x vs Sigma 2x EX DG MikeyBugs95 Pentax Camera and Field Accessories 2 12-31-2020 11:56 AM
For Sale - Sold: Teleconverters:Pentax F 1.7x mint, Tamron 1.4x BN, Kenko SHQ 1.5x Mint jjdgti Sold Items 11 03-11-2014 06:17 AM
Correct Sequence of Teleconverters (Metering With Teleconverters) MMurphy37 Troubleshooting and Beginner Help 19 09-18-2012 05:20 PM
For Sale - Sold: FA 50mm, Tamron 90mm, Sigma 150-500mm, Kenko 1.5x & 2x teleconverters (CAN) Doczi Sold Items 5 08-06-2010 08:24 AM
All times are GMT -7. The time now is 11:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
