Originally posted by clackers And also bear in mind that the JPGs at least are automatically corrected for vignetting by the camera, it brightens the corners.
But the vignetting is at least 2eV in the corners, according to a test done in this very forum!
And most wide angle lenses from all camera brands suffer from this unless the lens itself is big and heavy, containing a lot of glass.
I know the function, which is activated on the camera. I attach two photos taken now at 1.8, without correction of the camera. As you can see the vignetting is lower equally, and the one on the right is caused by the shadow of my snap point (the light comes from the left from an internal window). For shots in other situations I would say that even without corrections it is not noticeable. I don't want to argue that it doesn't produce any, I'd be silly, but just that I thought it was less relevant and that for 31 it's not strange that I didn't notice when it happens in much rarer situations of my use.
(jepg only resized). In any case in the end the purpose of my question was to understand if it was a problem with my lens 28 3.5 k, probably a little more or less depending on many reasons, but it is a common thing. Thanks.
