Originally posted by Michael Piziak 1) Question 1: Any tips on ISO, shutter speed, and aperture? (I just realized I forgot to fiddle with the aperture at all and took all the shots at f4)....
Fairly high. Depending on what you are shooting and what tracking ability you have expect to run between ISO 800 and ISO 6400 dependent on shutter speed. For shutter speed you will be limited to your tracking ability, so if untracked use the rule of 200 which is 200/focal length gives you your shutter speed in seconds. So for a 50mm lens that would mean that you can get pretty good results with little to no trailing (location in the sky dependent) at 4 seconds. For aperture you want to run as open as you can. Without knowing your lens I don't know what that point is but for my 50mm lenses I get great results with my SMC A 50/1.2 at f/2 and with with my S-M-C 50/1.4 Takumar I get great results at f/2.8. You don't need to increase the f-stop to gain depth of field as everything in space is at infinity from your lens's perspective, yes eve the moon and even with the biggest lens you could hang the camera off. Getting proper infinity focus is key and there are focusing masks that can help you nail that every time.
If you have tracking ability then the exposure time can go way up. Off of my little equatorial I use 30s as I only have one intervaolmeter but a couple of other release cables so I just do 30s shots and set that thing and forget it for the evening. I also have the O-GPS1 and will use that on my K-3 with longer glass and there at 400mm I can usually get great 20s exposures of deep sky objects all night long every night I am out.
Originally posted by Michael Piziak 2) Question2 : Is it possible for a very sharp 50mm lens to resolve, very distant objects in the night sky, almost as good as the Pentax 55-300mm lens? Especially when the 50mm is a sharp macro, like my lens is (my understanding is that macros are generally very sharp lens).
Yes. For example
here is a shot I did earlier this year using my K-3ii with the SMC A 50/1.2 and K-500 with the S-M-C 50/1.4 Takumar on the Cygnus region of the Milky Way showing the North Ameriacn Nebula and entire Veil Nebula. A 50mm on an APS-C camera will also frame up the parts of Orion with the most interesting features all at once like Barnard's loop, the Flame, Horse, Running Man, and Great Orion nebula along with the Witches Hat Nebula all at once. At 50mm Andromeda should show up clearly in your shots but will be small (about 6x the size in the night sky as the full moon) as well. With a 50mm lens expect to be shooting large things in the night sky so no Deep Sky Objects, but constellations, panos of the Milky Way, parts of the Milky Way, etc all work fine. Planets will be bright dots with bleed over into adjacent pixels as these really need long glass and by long glass I mean focal lengths measured in meters. I have recently
shot some
planets at 800mm and with some astro processing magic have some reasonable results but there is no replacement for focal length for shooting planets. Shooting the moon can be done but don't expect great results at 50mm but with a proper exposure you can get some detail, however longer is better and
I did this recently with my 800mm setup and my K-3.
Originally posted by Michael Piziak 3) Question 3: Photo 4 is my first capture of Star Trails (at 30 seconds shutter speed). I need to read up on how to get a longer shutter speed than 30 seconds. Any quick tips on how this is done, throw the tips at me. I recall something about bulb mode, etc...
Use a really heavy ultra sturdy tripod. Once you have that then get an intervolmeter and either have the camera in bulb mode and let the intervolmeter hold the shutter open for as long as you want or have it shoot continuously. If doing the shoot continuously method then combine all the shots using your favorite image combining software (for this I use hugin_stacker) and have the blend mode set to brightest.
While photoptimist says that most astro glass is expensive it doesn't have to be but good astro glass is generally very good glass. One of the best starter lenses for astrophotography of the big deep sky objects is any of the Pentax 200mm F/4 lenses from the S-M-C Takumar forward and those can be found fairly regularly in the US in great shape for $50 to $70. I still use my old S-M-C 200/4 Tak but you don't have to take my word for it as
others have gotten great results with other lenses using that optical formula. The lenses I use most for astro are:
Laowa 12mm f/2.8 Zero-D
SMC A 50/1.2
S-M-C 50/1.4 Tak
Samyang/Rokinon 135/2 UMC
S-M-C 200/4 Tak
Sigma 300/4 APO Tele Macro
SMC A* 400/2.8 ED [IF] (sometime with the 2X-L or 1.4X-L rear converters)
I recently acquired the SMC K 35/2 and SMC K 30.2.8 and only have tested the K 35/2 for astro and initial impressions look like it will be a great performer but I still need to test the K 30/2.8.
One other thing to keep in mind is that astro images are almost always stacked. Depending on what you are shooting and what OS you have for your computer there are very good free software options available. Deep Sky Stacker (DSS) has already been mentioned and I used that for a long time. There is also Sequator which has the option to freeze the ground and freeze the sky so I was able to stack
to get this image last year. I also know some people use the software Siril for stacking but I haven't figured that one out yet. So those are the free options I know about but if you are willing to pay for software I like Astro Pixel Processor (APP) and another great pay option is Pixel Insight
