Originally posted by jerryn I was looking to see if there a DSLR lens available 200-600mm @ F6 - F12 < $500.00
I already posted a list, but it didn't include two that actually meet your criteria:
Sigma 135-400 f4.5-5.6 and Sigma
170-500 f5-6.3. Both have more expensive (and better) similar versions available, but these particular models do fit your budget and get you that reach, and they were indeed designed for DSLR.
Another: although it doesn't reach quite as far and is not FF,
Pentax 55-300 PLM is very well regarded as some people's long reach lens (and useful for much more than that, besides).
Originally posted by jerryn I have not heard of an autofocus adapter. I am going to look for one.
The 1.7x AF adapter is very cool, but somewhat pricey. $250-$300 maybe. If you already have something like a quality 80-200 f2.8, 200 f2.8, or 300 f4, it's probably a decent option. If you're starting without those lenses and have to get one as well, you've found your way into $500 territory again anyways, and could probably choose a dedicated supertele instead.
It also may or may not satisfy your performance or IQ requirements with a given lens pairing, which will be harder to research in advance than if you were just buying a long lens to work by itself.
In any case, for someone who started a thread bemoaning the lack of "modern" lenses, the kooky-adapter+old lens method might wind up feeling a little 'kludged together' and unsophisticated before too long, even if it gets the reach you want.
Also be sure to consider a
Pentax Q with Kmount adapter. Smaller filesize, much worse low light performance, and no hope of AF (for supertele). But If you've ever dreamed of getting beyond 1000mm effective focal length...
