Originally posted by Michael Piziak I suppose it may come down to magnification. For example, will a 15-45mm tele lens on his Q camera have about the same magnification as a 83-249mm lens on say a FF camera (or whatever sensor size he is make an equivalence to in the video)....
Michael, this is where the "equivalence" get a bit confusing.
A 16-45mm lens has maximum magnification at 45mm obviously. A 83-249mm lens will have maximum at 249mm. The 249mm lens magnifies the image far, far more than the 45mm lens can, 5 times as much. These are the inherent optical properties of the lenses.
Where the "magnification" equivalence comes from is the fact that the image captured on the smaller sensor on say the Q needs to be enlarged much more than the full frame sensor, and it is this that gives the equivalent image size. Whether it is as good a quality image as a full frame one with a longer lens will depend on the pixel density of the smaller sensor among other things.
As an example I own a K-1 and an older K10D. The FF camera has a pixel count of 36m and the aps-c camera has 10m. If I use a 150mm lens on the former, and a 100mm lens on the latter I will get two images that look the same in terms of magnification and field of view, but one is a 36MP image and one is a 10MP image. Which do you think is going to look better, especially if I want to print the image ?
Put another way....if I use the same 100mm lens on both cameras, but then crop the FF one so it is identical to the aps-c one, I will end up with a cropped FF image of 16MP compared to the aps-c's 10MP.
Equivalence is not about lenses or formats in isolation. It is about lenses; formats;and sensor specification together.
