Show Printable Version 105 Likes Search this Thread
10-08-2021, 06:16 AM - 2 Likes   #106
Digitiser of Film
BigMackCam's Avatar
It's fully compatible with full frame film, but less so with full frame digital.
A number of very nice, compact primes from the film era have short exit pupil distances (the optical distance from the aperture in the lens to the plane of focus). When the lens is wide-open, the angle of refraction is so sharp, that some of the light from the lens bounces off the sensor instead of being captured by the microlenses on the pixels of sensor.
Technically speaking, it's not the main lens that is vignetting, it's the tiny microlenses. One could say that it is the camera that's not compatible with some full frame lenses!
The Jupiter-12 2.8/35 is another example... Excellent on 135 film (I've been told), but of limited use on a modern mirrorless digital camera for precisely the reasons you mention. However, rather than presenting as vignetting, in this case it results in colour-shift in the borders and corners...
10-08-2021, 08:32 AM - 1 Like   #107
Wheatfield's Avatar
UncleVanya, I think it's a pretty poor article, because it does not acknowledge that full frame means full frame lenses don't cover the image circle, that's the norm.
The mighty FA31 doesn't. It has 2 eV fall off in the corners. Zeisses don't. The Sigma 35mm Art f1.4 would be a fail by those standards. I suspect the DA*55 covers the full frame better than the FA50.
When I was looking at what lenses to sell when I ditched APS-C, I checked every DA lens I owned on the K1. None of the ones I had (I had all but a couple of the primes, and two of the zooms) gave especially good coverage on full frame. Those that didn't vignette more than I was willing to tolerate exhibited more corner softness than I was willing to tolerate. Some also had Sudden Death Motors which made them undesirable for reasons other than optical limitations.
BTW, the DFA*85/1.4 also has significant vignetting wide open, something that surprised me for what is a pretty expensive lens. It's gone by F2, but it's still there wide open.
D FA* 85/1.4 @ f1.4
D FA* 85/1.4 @ f2.0
10-08-2021, 01:45 PM - 1 Like   #108
Right. I soon discovered the very noticeable light falloff wide open with the FA 31mm Ltd on my K-1 II. This was not shown as being this pronounced in tests, because these were done some time ago on APS-C bodies, which of course did not reveal the entire image circle. But unlike lenses which do not cover the entire image circle, the problem disappears very rapidly with even slight stopping down with this lens.
I have found the DA* 200mm f/2.8 performs quite well as a FF lens. It seems to have been taken bodily from the FA* 200mm design of the film era and upgraded with WR and SDM. It seems from reports this is also true of the DA* 300mm f/4 as well, maybe taken from the "A" version. I have the FA* 300mm f/4.5 which of course was designed for 35mm film and has exhibited no problems.
My DA 40mm f/2.8 Ltd definitely has more light falloff wide open for FF use as opposed to APS-C than does my FA 43mm Ltd at f/2.8- which is negligible, but will improve as stopped down. Both are very fine lenses for either use.
10-08-2021, 01:54 PM - 1 Like   #109
That actually sounds like it might be kinda cool, depending on the effect given. Maybe I'll try one some day
Argghhh.... too many lenses.
Update: well, looks like it comes in a Kiev / Contax mount and M39 Leica mount. If there's an M42, I didn't find it. Whew... LBA / GAS dissipated for now.
10-08-2021, 02:04 PM - 1 Like   #110
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by yucatanPentax Quote
I wasn't aware of the Kiev / Contax version, but the LTM version is a rangefinder lens... short registration distance, and a rear element that comes alarmingly close to the film / sensor It's a lovely lens, and actually works well with B&W photography on my A7 MkII... but I know it would perform a lot better away from the frame centre on film...
10-11-2021, 10:45 PM   #111
Otis Memorial Pentaxian
clackers's Avatar
Sure. Even the Sigma 85mm Art was noted by Optical Limits as having a 1.8eV drop off in the corners. That's not just light level of course, it will mean detail's missing, too. And it affects the bokeh - more catseye at the edges instead of perfectly round.
10-12-2021, 08:19 PM - 1 Like   #112
Helpful In Some Respects
It's helpful to know the equv. or more to the point the factor. However, IMHO knowing the change in angle of view of a particular focal length (in degrees) is of more value if you're speaking in purely technical terms. Because in the end, what I'm really concerned with (besides depth-of-field or lack thereof) is coverage.
10-13-2021, 12:34 AM   #113
Even if you’re resolutely in the first camp, when you buy a new lens for your APS-C camera I bet you’re doing the conversion factor in your head anyway so don’t pretend it’s of no use lol.
10-13-2021, 02:22 AM   #114
QuoteOriginally posted by Graville Quote
I actually started my photographic journey shooting digital APS-C and so when I finally got a K-1 I was actually doing a reverse conversion -- figuring out what lenses I needed to match the ones I liked on my K-3. I don't do it any more for either camera, but I think the big thing is comparing to what you are used to shooting. If someone hasn't used full frame, using full frame equivalent focal lengths means very little to them.
10-13-2021, 06:40 AM   #115
Fogel70's Avatar
As FF EQ focal length been used on many small sensor fixed lens cameras including smartphones it is not only affecting those that have been, or are using FF format.
These small sensor cameras have been marketed using FF EQ focal length since beginning of digital photography.
If anyone know what focal length their smartphone use, they probably give you FF EQ focal length if you ask them, not the actual focal length.
10-13-2021, 12:55 PM   #116
Alex645's Avatar
QuoteOriginally posted by Fogel70 Quote
If you look up the new Apple iPhone 13 Pro Max, under specs, they only define the three lenses as telephoto, wide, and ultra wide. They do state the f/stops and the optical zoom amount, but no reference to focal lengths.
I do use my smartphone to take photos, but I couldn't tell you what the focal length is nor the FF equivalence. I can guess and I can research it, but if asked, I'd just say it's "wide".
10-13-2021, 01:33 PM   #117
normhead's Avatar
So, if you posted to Flickr it wouldn't give you the focal length above the exif?
The FL in Pentax cameras is listed both as the true focal length and the 35mm equivalent in my PP software, and in Exifextreme.
10-13-2021, 02:07 PM   #118
UncleVanya's Avatar
13mm, 26mm, 77mm equivalent. In that short simple statement I bet a lot of people now clearly understand the field of view better than ultrawide, "normal", and telephoto.
Smartphone "normal" has been around 28mm for a long time. Telephoto typically has meant 50mm which is hardly telephoto by any stretch of the imagination.
10-13-2021, 02:54 PM   #119
Alex645's Avatar
The context of my comment was regarding smartphone lens focal lengths.
Yes, there are many ways we can find the focal length via metadata. I'm just saying in context, most people shooting with their phones couldn't tell you what FL they shot at nor care.
With some effort, they could tell you but in my experience as a photographer, the only time I felt compelled to share or even know the phone's FL was when I has printed images and needed the info as signage in a gallery along with name, title, date, etc.
10-13-2021, 02:55 PM - 1 Like   #120
I suspect most people using phones don't know what focal length is.
100mm, aps-c, camera, cameras, comparison, efl, equivalence, equivalent, ff, film, image, k-mount, lens, lenses, magnification, mm, pentax, pentax lens, people, pixel, post, sensor, shooter, size, slr lens, sparrow, subject
Nature Isle aux Coudres @ 28 mm, 45 mm and 63 mm FL with DFA 28-105 mm HD and f/16. RICHARD L. Post Your Photos! 6 02-25-2022 05:25 AM
The bogeyman will catch you: equivalence, magnification and noise/dynamic range ;-) beholder3 General Photography 41 10-28-2019 05:47 PM
Ming Thein on format equivalence, engineering and practical envelope Unregistered User General Photography 41 06-19-2018 10:35 AM
For Sale - Sold: Brand New FA 31 mm, FA 77 mm, DA* 60-250 mm, DA* 300 mm ppkkcao Sold Items 14 11-02-2014 08:42 PM
Equivalence? 300mm/2.8 plus a 1.7X TC jpzk Pentax SLR Lens Discussion 10 09-28-2010 08:09 AM
All times are GMT -7. The time now is 11:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
