Originally posted by tibbitts
I bought a used copy here which still uses SDM, and have been happy with it overall because it isn't decentered (my main criteria for happiness with lenses.) But it can't (PDAF) autofocus within the ridiculously tiny +/-10 adjustment range of any of my cameras. And if it did I'm not convinced (just based on experience with other lenses) that it would be accurate at all the focal length settings. However being f2.8 I can focus manually (or CDAF) in most static situations. Honestly I can't get any of my bodies and lenses to focus reliably in circumstances when I really need AF. AF was fine even back in the K100 era when I had slower lenses and almost always used small apertures. Now that I have f2.8 lenses and occasionally want to use wider apertures (say, f2.8 or f4), not so much.
I've suffered front or back focusing with most of my lenses since I bought my first Pentax Camera, the *ist DS.
Maybe the lens with the worst focusing behaviour is my tamron 28-75mm, that optically is still a great lens. My problem with this lens is that you need different focusing corrections depending on focal length. That is, at tele end I need to correct for front focusing, but and the wide end I need to correct for back focusing. But it's still worse, because the focusing behaviour changes when you set the diaphragm to f5,6 or more. Starting at f2,8 you need one adjustment, but at f5.6 and above you need another. At f5,6 you can use this lens with just one single focusing correction for all the focal lengts, but when I planned to use this lens at f4,0 or so, I needed a focusing correction for f<5,6 and focal length in the range 50-75mm.
Maybe 3rd party lenses are worse related to focussing accuracy. Also I think that primes are 'better' related to focusing accuracy. I only have one prime with AF, my FA50/1,7. This lens only needs one adjustment and it focuses fine at any apperture, but my other lenses seems to 'shift' the focus a bit when you reach f5,6, compared to f5,0 and below.
Then there is the AF point accuracy, that is f5,6 for old Pentax bodies, maybe related to the different focusing adjustments above or below f5,6 ?
When I bought my K3-II, focussing accuracy was improved too, specially if I use the central AF points (f2,8 accuracy). My Tamron lens focuses way better on my K3-II compared to the K5.
But I still need to set different focusing corrections depending of the apperture for some lenses. As an example, my sigma 17-50mm needs -4 or +4 depending on the apperture, and my 50-135mm needs +2 or -2 (not a lot, really).
It seems the new K3-III have improved focusing accuracy a lot, is finally Pentax at the same level compared to other brands? I see reviews of many modern cameras that offer eye detection and I admit that I feel a bit envy.
Regards.
