Originally posted by EssJayEff A 50mm lens on full frame does not represent the human field of vision; it approximates only what one eye sees without magnification in a viewfinder. My field of vision using both eyes encompasses a much broader view than the coverage of a 50mm lens.
Human eye field of vision is at least 120 degrees, so it's clear than even 31mm lens on FF isn't wide enough for the camera sensor to see all what human binocular vision sees. There is always a confusion in forums about what 50mm normal lens means, it never meant to reproduce the same angle of view as the human binocular vision. Simple, 50mm lens gives field of view narrower than human eyes, but what's in the picture contain the same geometric proportion of objects in the frame as the human vision sees it. The whole point of a 50mm lens is to reproduce in images the same ratio of objects as seen in real life, which practically means I don't need to look through the camera viewfinder to compose an image that I will shoot with a 50mm lens, I can compose directly with my eyes, and of course not all what I can see with my eye will be in the frame because I see wider than a 50mm lens.
---------- Post added 29-10-21 at 16:47 ----------
Originally posted by jersey I think they fit the photography as a hobby, where you go around, quiet down, concentrate on what is around you.
Exactly. He is a professional photographer, but made the video for marketing purpose. This is the good aspect of that video, it's compelling to hobby photographers, the core of the market for such lens.
