03-12-2007, 06:36 AM   #1
mysterick's Avatar
M42 Screw mount adapter
I bought an 'other than Pentax' adapter on eBay awhile back. I just now have used it. It seemed to work fine until I tried to remove it from the K1000 body with the included wrench. The adapter turns back a little but then just stops. Does anyone have a similar experience and/or a suggestion as to how to extricate this little 'devil from my body'?
03-12-2007, 07:12 AM   #2
Branimir's Avatar
It shoud have two holes where you put "wrench". In one of those holes is also a stopper so that you cannot unscrew adapter. You have to press that stopper with the wrench and then when you turn a bit, you'll be stopped by camera's mount. Then you need to lift the wrench a bit, so that you still are able to turn the adapter, but to avoid the mount.
I hope this unstructured reply helps.
Branimir
03-12-2007, 07:26 AM   #3
mysterick's Avatar
Thanks
I'll try this when I get home. When I first got this l'l thing it went in and out very easily, so I know it is possible. Thanks
03-12-2007, 09:52 AM   #4
Mike Cash's Avatar
I'm guessing you did precisely the same thing I did. I put it in, turned it a bit, then turned it back and took it out again.
The difference with the lens mounted is that you turned the thing farther and the little spring latch engaged. Think about it, there has to be something in there to prevent the thing from just rotating freely right back out of the camera when the lens is mounted. Look very carefully and you'll see it.
03-12-2007, 01:32 PM   #5
mysterick's Avatar
Yup
I was trying too hard this morning on my way out of the house. I am home and I got it out (it's pretty snug) and I see how the two parts work together. Thank you both for your help.
adapter, k-mount, m42 screw, pentax lens, slr lens
M42 screw mount adapter - Pentax? Muse Troubleshooting and Beginner Help 42 08-20-2011 08:21 PM
? about M42 screw Lens to K mount adapter whitedogone Pentax SLR Lens Discussion 15 07-18-2008 01:39 PM
M42 screw-mount adapter advice jsherman999 Pentax SLR Lens Discussion 3 01-29-2008 10:39 AM
For Sale - Sold: FA: Original PENTAX Screw Mount to K Mount Adapter M42 HogRider Sold Items 0 10-21-2007 02:12 PM
All times are GMT -7. The time now is 09:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
