Originally posted by Blue Are you sure the F doesn't have a dual coil meter? The F had a revised meter design to take advantage of the "new" open-aperture metering, using the updated Super-Multi-Coated (S-M-C) Takumar lenses. The meter had higher power demands as a result. The ES was further revised to take a silver oxide battery and the ES II took 4.
The ES and ESII have greater power requirements, mainly for their electronic shutters.
The SP-F has a mechanical shutter.
No additional electrical power is required for full-aperture metering with SMC Takumar lenses.
An additional mechanical coupling is used to transmit set aperture to the camera's meter.
The SP-F meter turns on automatically whenever lens cap is removed.
Of course if left off for long periods battery will run down...
Chris
