Originally posted by mctaveck Hi all, is there anyone else that has the same issue on that lens? Just curious - if yes - if his bad copy falls in this serial number range
Thanks
Danilo
I just bought this lens and I notice the same issue. My serial number is 3302165. It is pretty inconsistent. Sometimes focus is fine others it is way off. I need to play around with it some more. But my early observations are that it seems more prevalent on subjects that are further away and at 50mm. I haven’t been able to reproduce it at 16mm when I pull in tight to a subject. In addition to the k3 iii I also have a k70. I was only able to reproduce it once one the k70 and that was with the outer focus point which isn’t cross type, and the focus was still pretty close just not spot on. I notice it more on k3 iii. And more so in lower light with the outer focus points (which also are not cross type on the k3 iii). To be honest I usually use center point and recompose. The only reason even noticed this was because this thread made me look for it. I also briefly tried to reproduce on my 70-200 and wasn’t able to though I only tried a few shots. It works perfectly in live view. I’m hoping it’s something they can address with a firmware update. Or perhaps I am just trying to exceed the focusing capabilities of those outer focus points. Though when it is off it can be way off. It’s not just slightly out.
