Originally posted by DeKay What about swapping out the blades from a damaged donor lens that has rounded edges.
I realise the chances of them fitting are slim, but if you found the right match it may work.
That's what I would think would have the greatest chance of success...
Obviously, there are some that would be pretty close, like the SMC vs HD limiteds with different blades...
Others would be extremely challenging... unless you wanted a preset lens or didn't mind disabling the aperture mechanism...
At some point, you might as well cut a slit in the lens body and use Waterhouse stops...
-Eric
