Show Printable Version 46 Likes Search this Thread
11-30-2021, 01:55 PM   #16
Digitiser of Film
BigMackCam's Avatar
Quite right Sir
On an unrelated note, you have the identical kitchen work surfaces and paint colour as my kitchen... unless you've been sneaking in when I'm not at home
Apologies to the OP - I'll cease and desist now
11-30-2021, 01:59 PM - 1 Like   #17
pschlute's Avatar
..... guilty....including drinking your champagne
11-30-2021, 02:13 PM - 2 Likes   #18
Wheatfield's Avatar
I have a couple of lenses that are made of unobtainium.
11-30-2021, 02:39 PM   #19
Not a Number's Avatar
"The stuff that dreams are made of"
11-30-2021, 02:47 PM - 2 Likes   #20
sergeremy's Avatar
I see what you did there
'A cute' mistake indeed, dare I say.
11-30-2021, 02:50 PM - 1 Like   #21
sergeremy's Avatar
Quite right Sir
Peter, you are losing all the bubbles there, without the pleasure of seeing them sensuously slithering up the glass wall...
11-30-2021, 02:52 PM - 1 Like   #22
MikeMcE's Avatar
Or no elements needed for coffee
Hang up and DRIVE!
11-30-2021, 02:54 PM - 3 Likes   #23
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by MikeMcE Quote
I hope you're gonna wipe that thing down before drinking coffee from it, Mike
11-30-2021, 03:49 PM - 2 Likes   #24
MikeMcE's Avatar
Nah, more flavor!
Hang up and DRIVE!
11-30-2021, 04:53 PM   #25
QuoteOriginally posted by stephen_G Quote
But what about the actual bodies of the lenese?
I'm looking specifically at the HD PENTAX-DA 55-300mmF4.5-6.3ED PLM WR RE.
The lens bodies of any brand for APS-C cameras with the zoom range of 55-300mm will be made of plastic. This above Pentax model is one of the newest, which incorporates the PLM technology for faster autofocus (AF). The RE stands for Retracting, as the lens barrel can be drawn in for extra compactness during carrying. But you have to be using a fairly later model of Pentax camera for this lens to function properly. The previous model, the HD DA 55-300mm f/4-5.8 WR is still available, which still depends on the camera's screw-driven AF. Nothing wrong with this, as some costly Pentax lenses still use this technology.
11-30-2021, 04:57 PM - 3 Likes   #26
Wheatfield's Avatar
Hang up and DRIVE!
I knew Canon lenses were good for something.
11-30-2021, 07:37 PM - 1 Like   #27
i_trax's Avatar
Hang up and DRIVE!
Mine is STABILIZED , good for milkshakes.
Oh, and you misplaced your hood?
IPad Air (4th generation)  Photo
11-30-2021, 08:44 PM - 4 Likes   #28
Digitalis's Avatar
Often cheap polymer thermoplastics,in other cases advanced carbon composites and semi-crystalline Polycarbonates and in other cases Metals such as Aluminium, Brass and Magnesium alloys. Lens barrels are seldom made of a singular material, they are frequently a mixed combination of materials.
All lens elements are glass.
Optical glass which is a silicon dioxide based amorphous solid*, is easily manufactured, formed and polished. However its optical properties and physical properties can be modified through the addition of various metal oxides and non-metals such as: Boron, Lead**, Copper, Cobalt, Tantalum, Cadmium**, Phosphorus**, Calcium, Vanadium, Magnesium, Sulfur and Arsenic**. These elements are added in trace amounts to alter mechanical properties as well as optical refractive index (and also to change colour transmittance of the lens itself). Older lenses can have radioactive elements such as, Thorium (mildly radioactive) Strontium (very radioactive) Lanthanum isotopes (strongly radioactive), as these elements decay radioactively the energy given off causes the lens element to eventually turn Yellow / Deep amber - The precise manner in which this yellowing occurs is a matter of ongoing debate: One hypothesis suggests it is the formation of colour centers created through highly energetic radioactive decay within the structure of the glass itself that cause the discoloration; another hypothesis is that the micrometer thin metallic coatings on the surface of the lens element ( there can be up to 13 different coatings of various metallic compositions on a single lens element) are affected by the radioactive decay and are (reversibly) transformed into an altered chemical state by it.
QuoteOriginally posted by i_trax Quote
Wouldn't having a gyroscopically stabilized container suppress any external force and lead to a disappointing milkshake?
QuoteOriginally posted by 35mmfilmfan Quote
in fond memory (or is that mammary ?) of Marie Antoinette
If those glasses were made these days they would look VERY different.
Except the ones that aren't For example, the hybrid aspherical elements in various models, including the DA15...
These are at least partially made of glass with a polycartbonate aspheric element bonded to it. I'd imagine it would be quite a nuisance to get the refractive indexes of the materials to match.
*Natural glass does exist, any natural process where high temperatures and a suitable silicate material is present can produce glass, lightning strikes on the beach (Fulgerites) Volcanic glass ( Obsidian). Also naturally grown crystals can be used for lenses, though they have pretty abysmal optical transmittance compared to synthetically lab grown ones.
** Thankfully the inclusion of these elements has been greatly reduced over the decades since RoHS and similar environmental safety and waste management measures have been put in place.
11-30-2021, 09:35 PM - 1 Like   #29
Alex645's Avatar
QuoteOriginally posted by sarge Quote
Most of the consumer grade lenses are plastic and glass some having metal mounts.
Most of the limited and pro grade DA* lenses are metal and glass.
A good majority of both are weather resistant.
And the weather resistant and all weather rated lenses have silicon rubber gaskets or rings.
12-01-2021, 03:48 AM - 1 Like   #30
It was not, I'm afraid - if you look closely, the word did not have the accented 'e' - which I admit could have been a grave mistake,
With these digressions, I bet the OP is really glad he asked !
The digressions are very entertainng, glad I asked the question!
---------- Post added 12-01-21 at 03:50 AM ----------
Indeed. It's almost as if there's some sort of competition that requires six posts a day before an entry can be claimed... for a lens that, I'm pretty certain, contains no plastic elements
Competition?
---------- Post added 12-01-21 at 03:54 AM ----------
QuoteOriginally posted by mikesbike Quote
Thanks for clarifying Mike.
55-300mm, bodies, competition, k-mount, lens, lenses, model, pentax, pentax lens, plastic, post, ricoh, slr lens, technology
Thematic Bear with me aslyfox Mini-Challenges, Games, and Photo Stories 2 10-06-2016 03:35 PM
Macro bear with me please, just starting out aslyfox Post Your Photos! 6 09-23-2016 05:58 PM
Baby Bear & Papa Bear Tony Belding Pentax Q 4 05-30-2015 04:14 AM
Nature How much can a Bear bear? Sorver Post Your Photos! 5 10-01-2014 01:24 PM
Beginner photographer, beginner with Pentax W.Scott Welcomes and Introductions 11 05-11-2014 11:44 PM
All times are GMT -7. The time now is 08:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
