This page has some interesting details about Takumar build and optical quality, that forum members might find interesting if they haven't already seen it:
Pentax Super-Takumar 24mm f/3.5 SM - of course I'm in no position to judge how accurate the information is.
Originally posted by Mercifulfate All great lenses but you are not going to get true 1:1 magnification unless you use the Macro Takumar or find a SMC Pentax-FA 50mm F2.8 Macro which also has 1:1. The FA rarely leaves the mount on my K-1.
Originally posted by northcoastgreg You really can't go wrong with any macro lens --- they're all very good. I would generally prefer an SMC coated lens, all else equal, but the other issue here is the 1:2 magnification of all K and M series macros and of most of Taks. The one exception is an old "macro-Takumar" from the mid-sixties, which is 1:1. For those shooting APS-C, 1:2 may not be that big a deal, but I've found 1:2 does not always provide enough magnification on FF.
I am, or rather was, somewhat trying to find Pentax replacements for a Nikon lens, the Micro-Nikkor 55mm f2.8 AIS, which has 0.5 magnification. I considered leitaxing this lens to use on the Pentax K-1, but we still have the (good working condition) Nikon FE camera it was purchased with, back in the middle 80s. I used this lens mostly as a general purpose "always on the camera" lens, but also enjoyed using it to photograph various things close up.
Replacing the Micro-Nikkor is doubly difficult because I used it first on a Canon APS-C digital camera, with the resulting "effectively 85ish mm" equivalent field of view; and then on a Sony A7 full-frame digital camera, via adapters. I really liked the field of view on the APS-C, including as a portrait lens, so I thought the 77mm Pentax limited (which I recently bought used) would fill the role of "55mm micro-nikkor on APS-C".
It turns out that however excellent the 77mm Limited is in most respects, it has a rather noticeable problem with "bokeh fringing/spherochromatism/secondary longitudinal chromatic aberration", which apparently is to be expected with wide-aperture lenses (
Lens Rentals | Blog). The first random test picture I took with the 77mm limited could be used as the "poster child" example of spherochromatism. The Micro-Nikkor doesn't have this characteristic.
So I spent some time perusing Cicala's excellent discussions of lens types and history of lenses, trying to learn a bit about lenses that can be made without spherochromatism. Along the way I saw a diagram for a Tessar lens and recognized it as being the same optical design as the Pentax 50mm F4 lenses. Perusing flickr examples of images taken with these 50mm F4 macro lenses, I couldn't find any spherochromatism (it was easy to find examples in images taken with the 77mm limited). Plus the bokeh from the 50mm F4 seems always pretty (I do like the Micro-Nikkor bokeh) and under the right circumstances somehow rather appealingly different from the Nikon lens. So I'm no longer trying to replace the Micro-Nikkor, the 50mm F4 macro is something different. Though hopefully it will be more or less equally "flat field", lacking distortion, and such.
The lens might arrive today, excitement builds!
