Originally posted by tjscot However, I worry I would want the 2.8 fixed aperture for low light.
Exactly.
Originally posted by tjscot I would have thought the 24-70 would be higher quality all around also, but that is not what I'm reading.
The 24-70 is higher quality? Yes and no.
I have both lenses. I use the DFA28-105 when weight is my primary concern (back packing or day time picture taking).
However, practically, from experience, the DFA 24-70 is actually more versatile when having a single lens:
- 28mm is often not quite as wide as I'd wish and 24mm does the trick
- f/2.8 is very useful for exposures without a tripod when the light isn't best, many times SR is good enough to get shots handheld up to the blue hour, shots you couldn't get sharp with the 28-105.
So, as you noticed, the key difference is the 24mm and f2.8, which IMO make the 24-70 a more usable lens in many situations.
Image quality wise, both lenses have their strength and weaknesses. My copy of 28-105 is sharp corner to corner from 35mm to 70mm, a bit better than my 24-70 at the same apertures, but the 24-70 has better overall rendering that the 28-105 doesn't have. Images just look better from the 24-70, due to color transmission , so anomalous glass element or whatever. I've used the 28-105 for people portraits and the colors look flat (remembers me the 18-55 on apsc), the 24-70 gives (subjective, IMO) more 3 dimensional look even at the same focal length and aperture. Also, the 28-105 is more sensitive to shutter shock at apertures from 1/30 to 1/200; the 24-70 suffer much less of this problem at the same shutter speeds.
Some people would push for the 28-105 because it's Pentax made, whereas the 24-70 is made by Tamron, but from a picture making standpoint purely as a user, I wouldn't make a choice based on who makes the lens.
Hope this helps for your choice.
