Originally posted by lotech as some said TTL will take care of that no need to worry about
Well the camera's meter will give you the correct exposure for the reflected light it records coming through the lens, but that actually misses the point.
If I take a reflective light reading from a hand held spot meter of my subject, I need to tell the meter some parameters. I need to tell it the ISO I am using and the aperture (say f2.8). The meter then tells me what shutter speed I need to set for correct exposure. Unlike the camera, the meter has no idea what focal length I am using, or whether it is a zoom or not.
Equally, if I use a hand held incident light meter (this measures the light falling on the subject, not the light reflected from it), I must tell it the same parameters to get an accurate reading. Again, the meter has no idea of focal length and no idea about the camera to subject distance. Whether I take the picture from 5 feet or 10 feet away, the exposure is the same.
A f2.8 constant-aperture zoom, set at f2.8 will record the same amount of light for any given focal length. It is the optical property of the lens that does this, nothing to do with the camera's meter or in-camera profiles.
