Originally posted by lotech Suppose we can produce a lens to prefect precision, by using high refractive index glasses is it possible to make the lens smaller that's what I want to know.
To answer your question, no, such lenses cannot be made smaller. Lenses like the DFA* 50/1.4 are big because there is no other way to do it. To get the resolution it is capable of, with the f1.4 apeture, it uses 15 elements in 9 groups. And it weighs 910 gr. Compare that with another couple of Pentax 50/1.4 lenses: the FA 50/1.4 has 7 elements in 6 groups and weighs 220 gr; the Super Takumar 50/1.4 (8 element) has 8 elements in six groups and weighs 245 gr. If your lens absolutely must be sharp from f1.4, the DFA* 50/1.4 is your only option. If you are happy with 50/1.4 lens that is very sharp from f4 onwards (and maybe can beat the DFA 50/1.4 upwards of f5.6), then the Super-Takumar (8 element) will do the job. If you want a good compromise lens - more than sharp enough for most applications - the FA 50/1.4 will be fine. It depends on what you need (and as someone else said, a Tessar will do just fine - and cost about $30)
In addition, I would say that price is not always a good guide to capability. Here is an example. This is a shot taken hand held with the DAL 55-300 at 300mm, wide open at f5.8. The DAL 55-300 is an inexpensive kit lens weighing 425gr (I picked up mine second hand for $90 (AUD)). The first pic shows the original framimg. The second is the crop. I don't think I could have done better with a $2000 or $3000 lens with about 30 elements in whatever groups and weighing a couple of kilograms.
