01-14-2022, 05:50 AM   #1
In the field with a D-FA 150-450
Hi
Can I ask how people carry the D-FA 150-450 when out and about.
I use the lens mostly with the K1ii attached to a shoulder strap and I tend to carry it either cradled in my arms and or by the tripod mount as I'm loath to put to much strain on the mount between camera and lens, I do suspect though that carrying it by the tripod mount is likely to put a strain on the lens mount. Either way tends to get uncomfortable due to the weight after a while but I don't want the faff of taking it out of a back pack or the like every few minutes.
Is there a better way?
Barry
01-14-2022, 06:07 AM   #2
bdery's Avatar
It fits sideways with a camera mounted in a sling such as the Peak Design (or Wandrd, or a few others)
Peak Design Everyday Sling Bag Review - Internal design | PentaxForums.com Reviews
There are a few cases, mainly by Think Tank, which specifically fit big lenses such as this one.
The lens also comes with a decent case, although it won't accept a camera mounted.
Bags such as the Peak Design Everyday Backpack can fit the lens vertically on one side:
Peak Design Everyday Backpack V2 and Backpack Zip Comparison Review - Introduction | PentaxForums.com Reviews
01-14-2022, 06:44 AM - 1 Like   #3
I use the 150-450 attached to a K1. I have the lens foot on a monopod. I carry it over my shoulder so the lens lays behind my neck and the camera on my shoulder. I get what you say about the strain on the attachment points. I just don't fling it around like a club.
01-14-2022, 06:50 AM - 1 Like   #4
bertwert's Avatar
I carry it attached to the KP and grip, recently I've been carrying it with a PD slide strap attached with one anchor on the tripod foot and one on the body. Previously I carried it with a two point attachment on the foot, but was worried about the foot failing, so adapted to this new method even if it's slightly less comfortable. The lens mount is plenty strong if you're supporting the lens by the foot, after all that's how it hangs on tripods and such.
When walking I steady or support it with one hand, but happy enough to let it hang when standing still. I generally keep a hand on the zoom ring to keep it at 150mm, as the two point means it hangs down and zooms to 450mm - which I feel is less sturdy for walking and banging around.
I don't carry it in a bag if I plan on shooting with it - it's of no use if it's hidden away and the bear runs across in front of you
01-14-2022, 08:56 AM - 3 Likes   #5
Michaelina2's Avatar
Like this...
While this setup shows me carrying the DA*300/4, I rig the 150-450 the same way. It places the kit's weight on the built-in lens foot. I can go all day. No problems...
Cheers.. M
01-14-2022, 10:21 AM - 1 Like   #6
if you browse the DFA 150-450 thread, inc searching for my posts (#1836), there are a number of suggestions. In brief, I added an eyebolt to the tripod foot on mine.
01-14-2022, 03:05 PM - 1 Like   #7
I have an eyebolt fitted to the tripod foot, and a Black rapid sling strap attached to that, but rarely let it hang loose on the strap. To keep it from moving around against my hip I usually use the tripod foot as a carry handle or cradle it.
The carry strap is more a safety restraint, but handy at times.
Cheers,
Terry
01-14-2022, 04:03 PM - 1 Like   #8
i used peak design strap and metal anchor mount from button of camera
01-14-2022, 06:35 PM   #9
I just invested on these iShoot accessories for my newly acquired Sigma 150-500mm.
Quick connect to the tripod is a bonus.
01-15-2022, 06:47 AM   #10
Thats an excellent idea but not what I was looking for.,thank you though.
---------- Post added 01-15-22 at 06:49 AM ----------
QuoteOriginally posted by bertwert Quote
There’s not many bears in Tyneside but I like the idea.
---------- Post added 01-15-22 at 06:55 AM ----------
QuoteOriginally posted by photoaki Quote
That looks exactly what I’m looking for provided they have one that’s compatible with the K1ii and the K3iii.
01-15-2022, 07:10 AM   #11
My Sigma 150-500mm has a strap fastened to the "cross-bar" which is probably an extension of the tripod-foot locking screw.
The camera hangs off my left shoulder, upside-down under my left arm, and can be brought into immediate use.
There's no strain on the camera's lens mount like this, but it does mean it's impractical to have a neck-strap on the body as well, so if I don't want to be using the "bigma" I'll usually pick up a different body
01-15-2022, 07:58 AM - 1 Like   #12
QuoteOriginally posted by bigbaz Quote
That looks exactly what Iím looking for provided they have one thatís compatible with the K1ii and the K3iii.
I have it mounted on the K1, so you should be good.
iShoot All-Metal Retractable
iShoot 220mm Long Camera Quick
01-15-2022, 03:49 PM   #13
Look at my Pentax Forums, User Reviews, 3rd Party Lenses, 150-500mm f5-6.3 Sigma discontinued Legacy Lens Zoom lens review. Find it with the latest Sigma Pentax Mount lens model reviews there: with OS, HSM, APO, etc. Mine is under "Climbmountainway", as lists various possible types of long lens mounting support systems. Lately it has been carried with the mentioned monopod, or a similar sling under the arm, as others mention, above. The other most employed support system is a window mount with a medium ball head for an automobile, made by Manfrotto, of Italy (or, as perhaps used, under Bogen named window mounts or heads on ebay). I use the on lens stablization, "1", with the camera body, where I keep a slight drag, not locked down, on the monopod ball head or the window mount ball head (as such too occasionally on such a tripod alike employed head). Then the Optical stablization functions. For the Pentax long lens zoom, you would use the camera with SR on, with the camera with some drag selected on the type of support head, accounting for the changing Pentax long zoom lens focal lengths.
Last edited by climbmountainway; 01-15-2022 at 04:02 PM. Reason: changed a punctuation
backpack, d-fa, design, foot, hand, idea, k-mount, lens, mount, peak, peak design, pentax lens, post, reviews, sling, slr lens, strain, tripod
To 150-450 or not to 150-450? bertwert Pentax SLR Lens Discussion 50 01-05-2022 11:47 AM
DFA 150-450 Reporting 310 when at 150 Mikesul Pentax SLR Lens Discussion 9 11-21-2018 04:18 PM
Pentax 150-450 vs Sigma 150-500 questions stemked Pentax SLR Lens Discussion 18 05-28-2018 09:38 AM
Owners of Pentax 55-300 and 150-450 - Are you still glad you bought the 150-450? Joyce Keay Pentax K-70 16 02-17-2018 05:55 PM
150-450 v 150-500 v 300 + 1.4TC FreeSpirit9 Pentax SLR Lens Discussion 62 05-17-2016 02:35 PM
All times are GMT -7. The time now is 06:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
