Dear friends,
I got a very good deal (too good to pass) on a well-used FA*24mm.
So far I like the output of the lens and it works well
in AF mode despite quite a bit of dust in the rear group.
However, I have a problem with the focusing ring when in "Manual" position:
Each time I reach the end of the focus scale there is a
very soft stop (much lighter than on any DA lens I know; in fact it is only barey noticeable) and then it is really difficult to get the focus ring to "engage" again and drag the focus back within the scale. More often than not, I need to play with the clutch mechanism and/or squeeze the barrel quite hard while turning back. I'm not sure if that is clear?
For instance, focusing out, I will inadvertently go further than infinity with the ring; the scale and actual focus stay at infinity; and then turning back left, nothing happens and the lens stays stuck at infinity until I manage to re-engage it again. The same can happen at the close end of the scale.
Note that, as long as I stay within the scale, I have usually no issues at all. And AF has no problem at all either.
Does that ring a bell with anyone? Is that a common issue on FA*s with their "elaborate" mechanism? Is there a known fix?
Thanks
