The FA Limiteds are old lenses, new high end lenses are very likely to be technically better. The best new lenses may also have nicer rendering but this is a matter of taste. From what I've seen many of the Voigts are very nice rendering lenses. I'm not sure about this but I also think that the Sony sensor build up reduces performance not only with Leica M lenses but also other wide angles unless designed for the sensor.
Originally posted by andy271 My conclusion aboutthe hd31 is that is has:
* Ugly yellow colour balance.
Generally speaking the HD coating gives a slightly more magenta tone as expected from the improved transmission. This is (barely) noticeable with the lenses I've tried with both coatings.
Originally posted by andy271 *HD coating is terrible with stray light
See HDhere:HD vs. SMC Pentax FA Limited Lenses Review - Flare and Ghosting | PentaxForums.com Reviews
SeeMUCH better SMC here:HD vs. SMC Pentax FA Limited Lenses Review - Flare and Ghosting | PentaxForums.com Reviews
As others have pointed out your SMC vs HD thing is confusing. All evidence, including your links show that HD coating helps reduce flare.
Originally posted by andy271 *HD has uglier starbursts
Many agree with you but I don't. Spiky show off special effects should have to place in a serious lens. Leave that to lensbaby.
Originally posted by andy271 * Bad sharpness
* Bad qualitycontrol
I have no idea about this.
Originally posted by andy271 * HD coating killed the pop (3d) too, by over-improvingdynamic range. Pictures are flat and boring.
This is makes no sense. More dynamic range will hardly make your images flat. A flat image lacks contrast and dynamic range.
