Originally posted by Damn_sam Is there an adapter or Remedy for this to work?
I think if you remove the three screws that part will come out. Then with a cutting tool you can remove the protruding part and it probably will fit. The part was probably used on multiple lenses and was designed to protect the aperture lever used in another lens. Since this lens has a fixed aperture, removal has no negatives.
---------- Post added 02-11-22 at 08:49 AM ----------
You do want to be careful not to allow the dust created a or metal fragments from contaminating your gear, so cut it in a place where you can clean up the debris and it won’t get into the air if you use a tool that might produce fine airborne debris. A simple cutting wheel job done outside is probably good. A manual removal using a smaller hacksaw also might work. You may want to use flat black paint to mask any shiny scars left after removal.
---------- Post added 02-11-22 at 08:50 AM ----------
And be sure to avoid bending the mount!
