Originally posted by Jeff With the TC it'll be f5.6 throughout - it's worth that extra stop over the f6.3 of the PLM for me...
There are times when that one-third of a stop (f5.6 v f6.3) can matter a bit - like when you already have a very slow shutter or very high ISO, or you are struggling to focus with an off-centre AF point.
But don't give that too much weight. The PLM is f5.6 until about 260mm, so if you need f5.6 you can just back off a bit without losing much magnification. The PLM is very good wide open too, so you can use it with confidence at its maximum aperture, whether it's f5.6 (230mm) ...
... or f6.3 (300mm)
It's not just a wildlife lens either. If you look in the 55-300 "show us what it can do" thread, you will see lots of excellent landscapes too. I've been happy with it there too.
For me the compact size and light weight are huge pluses. I can get a carry kit of KP, DA 15 Limited, DA 20-40 Limited and 55-300 PLM, plus a flash and trigger into a smallish bag. At a pinch I could travel the world with that kit. The PLM also pairs well with the DA 18-135 or DA 16-85. Or sometimes the DA 12-24 and a 35 or 43mm prime.
To my mind, compactness and light weight are big advantages of APS-C, and the KP in particular. You are losing a lot of those advantages if you confine yourself to FF lenses, where there is a lighter more compact APS-C alternative. The fact that you have a KP as well as a K-1 suggests that you don't always want the extra weight and bulk, and that you like the crop sensor for some things. Just go with that!
