Originally posted by Michael Piziak I thought all the Tukumar were screw mount, as that's what I see when shopping. I did just google it and you are correct that some were k mount - what I read though said the k mount versions were of inferior quality & shouldn't be a target for collectors.....
Further question: I suppose, using a Tukumar lens (with green button), is very similar to using an M k mount lens, eh? Many Tukumar lens simply cost less, because they aren't k mount, and would make for affordable additions to ones collection (?)
Alleged "inferior" build quality doesn't necessarily mean inferior optical quality … just means if you drop it it's less likely to bounce
I don't consider myself a "collector", more of an "accumulator" … I pick up interesting stuff at "sensible" prices … sometimes I get lucky
I use the green button in Manual Mode exclusively when I'm not using "A" capable lenses, screw mount or K mount … just my way of ensuring I don't make a mistake!
My "manual mantra" is
F-A-S-T :-
Focus, with the lens wide open
Aperture, close down as required
Shutter, press the green button to get a reading
Take the picture
I've been using this since the '60's … it still works
Now I've got my K-3iii I've got the option of using the older non-A K-mount lenses in Av etc., but old habits die hard!
