Originally posted by m96
How about if I like an older lens, might I expect same behavior with an F zoom lens, or an A zoom?
As long as the aperture ring is set to the "A" position of an F or FA lens, the camera has full control of the lens aperture and will behave like a new DA of DFA lens.
However, A lenses don't communicate with the camera, therefore the current focal lenght is not recognized by the camera, as I only have a constant aperture zoom lens (A lens) I am not totally certain what happens in cases you select an aperture between the variable aperture values of the lens, when zooming (with a variable aperture zoom lens)
edit: when the aperture ring is set to something else than the A position, the lens will operate like a M or K lens.
The functionality will then depend on the camera body (the new K-3III offers more functions for M or K lenses than the older camera bodys do): the lens can be used in M or B mode without restrictions (with green button metering), or in Av mode (but the lens will not stop down in Av mode, no matter where the apeture ring is set to -> the new K-3iii will stop down the lens in Av mode as far as I know)
