Originally posted by LaurenOE I did...and waited a LONG time. Like way longer than when I upgrade a Sony lens. It appears the Monster people are using the same software as Sony uses to upgrade native Sony glass, so not sure how much longer it should take?
Also, not sure if my "Can't continue" message is a "Time-out" or an actual problem.
What Sony body did you use?
In addition to the A7RV and FX3, I have an A6500, A7SII and A7RII.
I could use my husband's ZV-E10 if that matters?
My SII and RII are in the original boxes waiting to be sold, so I don't want to have to go and use them.
Lauren
Meanwhile I had the courage to perform the update. I have a A7II with the latest firmware and the update took about a second.
Rudy
---------- Post added 01-06-23 at 04:28 AM ----------
Originally posted by UncleVanya I haven’t gotten the F AFA 1.7x to work with any lens yet. Has anyone else gotten it to work?
I did got it to work. I quickly tested two lenses:
- SMC Pentax-A 50 mm F1:2: works fine (the only A-lens I have)
- Tamron Adaptall 2 SP Macro 90mm F 1:2.8 (72B): more or less works
You do have to prefocus the lens manually until the adapter's AF works. With my A-lens I had to set the manual focus distance on the lens to around 10m, to have a working AF around 2m away.
With the Tamron Adaptall lens (with PK-A adapter) it is more difficult, also due to the small depth of field, you have to turn the manual focus ring until the AF is responding. Actually, focus peaking is easier and more accurate.
Originally posted by UncleVanya Has anyone tried the new firmware on an “A” series lens and the f 1.7x? How does the camera know what focal length the lens is?
It does not know. The adapter is communicating a focal length of 35 mm with the F AFA 1.7x.
More tests will follow.
Rudy
