Originally posted by Wasp An update on my post above. It is almost definitely balsamic separation. I have given up on the lens. Luckily for me, a copy of the A version turned up in my valley and I snapped it up. It is in perfect shape and delivers the SMC magic.
Never give up on balsam separation if you have a practical streak.
I use modern synthetic balsam,and after cleaning and recentrering the separated elements, put a drop of the cement between them, then put the element block under a UV light-I use one that is designed to harden modern nail varnish! The only issue with cemented elements, assuming they are still connected, is to separate them. I use dichloromethane, or a derivative of it, which will separate the elements if they are soaked in it over about 24 hours. One thing to be aware of is that the liquid is VERY evaporative, so make sure the container is air-tight, both the one the elements are soaking in, and the original container.
