Originally posted by Smolk Which I feared... It is just a difficult choice, in part because I cannot try either locally, to see how they feel in the hand. That's what underpins my question.
I tried to make a large lens heavier by attaching batteries to it (don't ask) but you can't replicate this easily. I have lenses that are heavier for my Rolleiflex 6008, but then that body feels and holds very differently, too (rather good in fact: the weight is more of an issue on my shoulder than in my hands).
Thanks all for responding. I'm somehow hoping some deal comes my way and will help settle the matter
Well, the DA* 16-50mm f/2.8 PLM is going to feel llike a different animal in terms of handling. But it is designed to be handled, and I'm sure well-designed. Though I've never handled one, I know from experience with other lenses of similar size and weight, although well-designed it is a beast. The DA 20-40mm f/2.8-4 is actually very much the opposite. This beauty is a compact wonder, with lightweight carrying and great handling a big part of its persona. Large and heavy is the price paid for the f/2.8 aperture needed to address certain circumstances and/or needs. it can provide greater shutter speed under the same lighting. This is what it boils down to, and this is why many of us wind up with both types.
You can see for yourself how the DA 20-40mm Ltd lens performs in a visual test by Imaging Resource. They give it a very high rating. Scroll down to the test scene. When you click on it, you will be able to choose from open aperture to smaller aperture. You can choose a section of the scene for a close-up view by clicking on that spot. To get over near an edge, the spot where the top of the paint brush is near the circular graph will give you an idea of sharpness near an edge area. For center, the inner edge of the fabric basket, for example. The images and writing on the bottles provide good evaluations. I can tell you from examining this same test of other lenses, this Pentax lens performs extremely well.
Lenses generally do not perform as well near edges or certainly in corners as well as they do in the central area. This is to be expected. But this lens does better than most. The same for wide open vs. stopped down. This lens does better than most. The same at the extreme FL of a zoom lens. This lens does better than most.
(one heads up is- I discovered in the case of one other lens test done here, the focus of the test shot was obviously out of focus. But that has been very rare among the many lenses I've seen tested here using this same test)
Could the DA* 16-50mm f/2.8 PLM do better at 40mm f/4, especially at edges? Probably- because with this lens that means not wide open and not at its extreme FL. Would it be better at 20mm f/2.8? Probably, since with this lens it is not at its extreme FL. Yet, the DA 20-40mm Ltd performs very well at its extremes, a remarkable accomplishment, and in such a high-quality compact package. So if convenient carrying and handling are a primary concern for you, this one is very hard or impossible to equal. But if you really need that f/2.8 constant aperture throughout, then you have to put up with price/weight/ inconvenience. That very new Pentax PLM lens has not yet faced lab or visual test evaluations.
