Originally posted by STARHUNTER94 That's a good point. I think I've never thought this way outside of "which zoom range do I need" so I've always had 1-2 lenses in my bag. Short and Long. I'm sure this is because I need to grow as a photographer and move my legs more and look at the scene before firing away.
This is absolutely true. There are different approaches according also to needs where one can say a versatile setup is the way to go. What you are describing here would entail using a prime lens or two. If the interest is a prime lens as a walk-around lens, then here again versatile would come to mind. A versatile FL is one that would be suitable for many conditions one might happen upon. Usually, the preference is for wide angle for general use, which means not too wide. But if wishing to do more singling out of subjects from the scene, or a slight crop effect, or where much of the scene will be at some distance away, then a normal lens or short tele would be the ticket. Traditionally, the normal, all purpose prime lens for 35mm film photography has been the fast 50mm. But with APS-C the change in angle of view converts the fast 50mm to better serve other uses, such as being a very good portrait lens choice. This means a great savings over getting a lens yielding the same usage for 35mm film or a full-frame DSLR. That would be a 77 to 85mm f/1.8 which would be quite costly. The inexpensive DA 50mm f/1.8 is a good choice here. Also great for low light uses, due to its f/1.8 aperture, and good performance even wide open. Such a lens could blur background to make a subject stand out from it much better than the 50mm end of your kit lens, and can deliver 8 times the shutter speed under the same conditions, not to mention better image quality.
Other situation where versatility is important, this time going towards zoom lenses, are certain events such as a garden party or a graduation, for example. The DA 18-135mm is perfect for these kinds of scenarios. You can get a lot of good results with a variety of compositions while not needing to move much from your position, and/or can catch some good candids, altering framing as needed. Of course, this would also be a great choice if going around with a group, where changing lenses would cause delay and inconvenience to others and should be avoided.
