The
70-210 f4 is a little lighter.
The
55-300 PLM is definitely a lot lighter and more compact, but you're really giving up a lot of speed with that one. Still, it's known to be a great lens, and a lot of people post great wildlife shots with it. I think some people even use it with the 1.4x TC in good light with good results, and that combo might fit the bill to get you past 400 without being too heavy.
I would probably hang on to the 300 f4 for times of lower light or when you want more IQ, though. You could look for a copy of one of the F* or FA* 300mm lenses, which are basically the same lens as your DA*300 but a little smaller.
Have you considered using a monopod and 1axis head to help hold the weight up and steady? That might let you use larger lenses comfortably, and the
150-450 (or a bigma if you're not looking to spend that much) sounds like it would really be what you're looking for, if not for the weight.
