Originally posted by BigMackCam I agree... though I will say, the action of the focus ring on the HD FA35/2 feels a little better to me than F and older FA lenses including the SMC FA35/2, and the textured rubber focusing ring is nicer to use than the SMC version's smooth one. I find MF perfectly acceptable with the HD version, though it's not as pleasurable as using an FA or DA Limited...
Originally posted by pres589 BMC: I would like to try that HD FA 35 on one of my film bodies. It does look like they tried to put some modern thinking into the handling without making too many changes into the lens. I'm also (shudder) realizing that as much as I like 24 and 28mm lenses on my crop DSLR, I should probably get over my hangups about 35mm lenses on full frame.
Originally posted by JensE The HD lens is identical except for some cosmetic texture on the outside and HD coating instead of smc on the lens elements.
And yet, having used both the SMC and HD FA35/2, I can say with some confidence that the HD version I own has a nicer manual focusing action - not "night and day" different, but
definitely nicer, with better damping. The textured focusing ring
does make a surprisingly noticeable difference, being more obvious to the fingertips when reaching for it and feeling more positive in use. The SMC's smooth ring is virtually flush with the body, so - as with my FA50/1.4 - I found myself operating it from the leading edge to make sure I was holding the ring and not the barrel, like an F-series lens. Aside from that, it may simply be that my HD copy was bought brand new, whilst the SMC versions I've tried were used, subject therefore to some wear and tear, and possibly even a little drying-out of lubricant.
I'm going to revise my earlier comment and say that I actually prefer the focusing action on my HD FA35/2 to my DA Limited primes. It feels more traditional, like a nicely-greased helicoid on an A-series prime. The DA Limiteds focus smoothly, but feel like the mechanisms are constructed with fine-toothed gears...
