Thanks for the replies everyone!
Originally posted by BigMackCam I use the Sigma 17-50 f/2.8 on my K-3 and K-3II. I've found that going through the AF cycle twice (i.e. focus once and wait for it to lock, then focus again) is the only way to guarantee accurate focus. with this lens and body combo. It's a little annoying, but for my kind of shooting it's usually not an issue, and the image quality from the lens makes it a worthwhile compromise. I know some other folks in these forums have noticed the same behaviour, so I'd say it's pretty common.
Thanks, I'll try this for now and see if there's any improvement. A bit of a workaround, but I could happily live with it if it saves me the cost of a new lens
Originally posted by zapp Do you own any Pentax lens to confirm that it performs differently from the Sigmas? I had bad AF in Pentax K5 when working in artificial light as well as two Sigma ART35 failing AF-wise on K1ii. With K3ii illumination should not be the problem. Technique may also cause inaccurate focus, touching the shutter release button for readjusted focus, using different AF pattern, … what can I say the new 16-50 should do it. The 20-40 is a decent lens as well. Pricing, but working.
I have a few others that I use regularly. For low light situations my usual companion to the Sigma 17-50 is the Pentax 50-135, which I love and gives fairly reliable results. When I was trying to calibrate the Sigmas I also did some tests with my DA 50mm f1.8, which behaved much more consistently. So I do think the problem lies with the Sigma lenses. The body's had some
really strange focusing problems in the past, but that looked different than the simple front- or backfocusing I'm seeing with the Sigmas.
Originally posted by C_Jones I have the Pentax 16-85 and it provides excellent images. The AF is very reliable. I have it on my Pentax K-3 II.
I have the 16-85 and like it, it's usually the only lens I take with me when I travel. But in low light it's just not fast enough.
