I believe that they are like what you describe. I have had to do that with most of my older lenses (they get real close but not all the way to infinity when checked with a bahtinov mask) and the process is remove the name plate, remove another ring and then you can get at the focus screws. I have done this to my K 35/2, K 30/2.8, A 28/2.8, and A 50/1.2 so I would assume that the K135/2.5 would be the same as would the M50/1.4 since my K lenses that I have done this to are the same and the later A lenses are also that way so I would be surprised if the M was different.
