It looks like you are using a (version of the) ISO 12233 chart.
If your chart has all the details it should, I would suggest shooting it such that is just fills the frame of your camera (at the proper aspect ratio), at whatever focal length you are using. That's how the chart is meant to be used.
In that case, your K-1 should more than resolve all the lines at the "20"s on the chart if the lens is up to snuff.
I made my own version of the resolution chart, by blowing it up by about a factor of 3 or 4, so my printer, at 1200 dpi, would adequately resolve it. The pdf given here (
ISO 12233 Test Chart) is a good place to get a pdf which can be scaled up to whatever size you need.
Here's my alternate version of the chart, and a zoom into the upper left corner, taken with my K-1 and 100mm Pentax macro. All the corners are nice and sharp with the macro. My chart is scaled such that it should fill the width of a normal ratio (1:1.5) frame and the resolution numbers will be correct. The letter C is there because I have three of these, which I used for my students to make test shots with their cameras. The crosshairs in the middle allow for good focusing, and the color chart - why not!
I'd be glad to make available high-resolution files of the resolution "wedges" or whatever they are called.
