Show Printable Version 10 Likes Search this Thread
04-11-2022, 10:29 AM   #1
Wide angle wr lens with filter capabilities?
So, I'm heading to Iceland and Faroe islands soon.
I will be taking my k1
My favorite lens, the 200mm f2.8 will.bw coming with me.
So will the 100mm macro.
Both lenses are wr.
The other lens I'm planning on taking is the 31mm, which, obviously is not wr.
Yes, I know the 28-105 and the 24-70 exist as wr lenses. The 15-30 is a chonky one and adding Nd filters is a tall task I don't want to get into.
Is there anything wider than the 31mm and has wr? A prime, perhaps? I don't mind using the k1 in crop mode, so I could use those primes...but I'm not sure if there are any other possibilities.
I used to have the 24-70, which was decent, but not my cup of tea as it is a zoom.
Any inputs in this would be greatly appreciated
(Yes, I do take lots of panoramas, so that can be used with the 100mm. But for long exposure stuff, not sure if that is possible with making panoramas)
04-11-2022, 10:46 AM   #2
ramseybuckeye's Avatar
There is the APS-C DA 20-40 which is WR and is exceptional. Not a prime, but it is a Limited.
04-11-2022, 10:55 AM - 1 Like   #3
jslifoaw's Avatar
The DFA21 Limited is WR.
04-11-2022, 11:00 AM - 2 Likes   #4
Also keep in mind you can do composite frame averaging to get the effect of ND filters (without the need for one) in some situations. Such as shooting long exposures of waterfalls in bright sunlight, for instance.
04-11-2022, 11:37 AM   #5
UncleVanya's Avatar
D FA 21 would be the first recommendation followed by the DA* 11-18 which will cover full frame at the long end.
04-11-2022, 11:45 AM - 2 Likes   #6
You might consider picking up an Irix 15mm Blackstone which is full frame, water resistant, and can take either screw-on front filters or gel ND filters at the rear.
04-11-2022, 12:24 PM   #7
All these are great recommendations, keep them coming!
Not that it's the state of the art, or superb lens, I could just get the 18-55 wr lens for when the 31mm isn't recommended for the weather.
As for composite framing, or interval shooting, that could work in some settings.
04-11-2022, 07:15 PM   #8
UncleVanya's Avatar
QuoteOriginally posted by ramseybuckeye Quote
That lens does an ok job on ff for part of the range. It will be wider than 18mm apsc as it tends to be pretty much reasonably FF at about 24mm (18mm on apsc is more like 28mm FF)
---------- Post added 04-11-22 at 10:22 PM ----------
QuoteOriginally posted by hadi Quote
18-55 on apsc isn’t any wider than the 28-105, which itself is only slightly wider than the 31. 31 is wide - not super wide but wide. Once upon a time 35 was “wide” 28 was wider, and 24 was ultra-wide. Today standards are different but the fa 31 may surprise you - albeit not weather resistant.
The D FA 21 and the Irix 15 are super wide indeed.
Why WR? Could you just get a lens coat and an umbrella? The FA J 18-35 is a fun inexpensive option that won’t compete with the D FA 21 but might work well if the 18-55 WR is on your radar.
04-11-2022, 11:46 PM   #9
pid
I would definitely take my DFA 21 with me. It renders colors so beautyful. If you dont have it buy it!
04-12-2022, 08:14 AM   #10
My suggestion would be the FA 15-30 it may be a little cumbersome to get filters, but that lens is a WR workhorse. The only filters/holder you can use is the Haida one, but any 150mm filter will fit the holder.
04-12-2022, 08:53 AM   #11
Reason for wr is I plan on doing lots of long exposure. The conditions of Faroe islands and Iceland, from what I've seen, and heard, is unrelentless. Random rain storms, and spray. It's hard to predict what the conditions are like.
04-12-2022, 08:56 AM   #12
Seeker of Knowledge
aslyfox's Avatar
you could consider the old way of protecting the camera and lens
Camera Rain Cover - Bing images
04-12-2022, 08:57 AM - 1 Like   #13
UncleVanya's Avatar
QuoteOriginally posted by aslyfox Quote
Given the fact that weather resistance isn’t covered by warranty… I’d probably do both.
04-12-2022, 10:34 AM - 1 Like   #14
redrockcoulee's Avatar
Not heavy rain often more like every mists. I was in both last fall. In the Fareos you do need a wide angle lens much more than a long one.
04-12-2022, 04:42 PM   #15
Not true. I use the WonderPana filter holder system https://fotodioxpro.com/collections/wonderpana/products/wonderpana-tm1530 and there is also Wine County Camera's 150mm filter system 150mm Master Filter and Holder Kit ? Wine Country Camera. I use their 100mm filter system on my normal sized lenses.
I like the WonderPana system on the 15-30 because I can attach the holder and use a clip-on lens cap that almost fits in to my pocket.
QuoteOriginally posted by bikehead90 Quote
100mm, 18mm, 31mm, angle wr lens, apsc, fa, ff, k-mount, k1, lens, lens with filter, lenses, panoramas, pentax lens, slr lens, weather, wr
Practical Impacts of new K3-III capabilities on Lens Selection - Coatings & Apertures GlassJunkie Pentax K-3 III 6 07-16-2021 12:07 PM
Get wide angle lens from an extreme angle lens jorgegetafe Pentax SLR Lens Discussion 7 10-08-2015 12:53 AM
Wanted - Acquired: Wide / Ultra Wide angle lens for my K-5 GWARmachine Sold Items 3 03-23-2013 12:03 AM
All times are GMT -7. The time now is 11:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
