F* 300mm f/4.5 Black Edition
Recently, I was lucky to buy a used Pentax F* 300mm f/4.5 for a bargain price, from a friendly Belgian lady. The reason for the low price was its looks: the white paint on this lens is easily damaged, and this obviously was a well used copy.
I personally am not thrilled about the white-lens-look, and a copy full of scratches and markings is even worse. So I decided to give it a make-over: with some black insulation tape, matte black self-adhesive foil for redecorating kitchen cabinets, knife, scissors and some black marker for the details I turned it into (I guess) the only F* 300mm f/4.5 'Black Edition'. See pictures below. I included a comparison shot with the DA* 300mm, and unfortunately forgot to take a picture of the F* before this 'treatment'. It is an easy job, no disassembly required and everyone with a bit of patience can do this. A tricky part was to leave the thin gold line on the hood uncovered. It is purely cosmetic, everything still works as it should.
Full disclosure: the foil/tape didn't work beneath the built-in hood, that area needs something even thinner or I might simply have to paint it. But so far, I found no need for extending the hood even when shooting straight into sunlight, so I think I'll keep it like this.
I'm quite pleased with the way this turned out, although I have to see how it will hold up in use, and I may revisit some details later. I think the black outfit it suits the F* quite well, would be a great compact 300mm option if it would be released again, IMO.
Anyone else tried a cosmetic lens make-over/restoration?
