03-15-2007, 07:23 AM   #16
QuoteOriginally posted by skaktuss Quote
i've tested my prime at meny aperture sizes and i can say that k100 light metering is not very accurate. when aperture is wide open, after pressing ae-l result is bright and natural, but, for example, at aperture 16 picture is underexposed pretty much, so i have to turn wheel for 1-2 clicks. therefore the process is not so fast and easy.
The only correct way to use a manual aperture lens on the K10D body is to set the camera in M and when you want to get the correct exposure hit the "Green" button next to the shutter so the camera knows what aperature you have the lens set at. This information is buried in the manual so hopefully this helps you. Just played with this option last night by the way with a couple of lenses I dug out of my closet which was the 50mm 1.7 and the 28mm 2.8, they are so sharp and now have placed them into my bag for some super sharp shots.
03-15-2007, 09:00 AM   #17
Codiac, and y'all, thanks for your comments. There is no green button on the K100D camera I have. Is the green button the equivalent of my AE-L button. Freddy
03-15-2007, 09:08 AM   #18
Mike Cash's Avatar
Menu:
Custom Setting:
"AE-L bttn on M expsr" 2 (Tv Shift)
"Using aperture ring" 2 (Permitted)
Make sure you have those two menu settings. Choose "M" for your mode.
Select your aperture with the ring on the lens.
Focus.
Hit the AE-L button. The camera will close down the lens iris to your selected aperture, meter the light, and automatically set the shutter speed for you.
Shoot your picture.
If you later on get some "A" lenses, the process is much easier. Also much easier with screwmount lenses.
03-15-2007, 09:08 AM   #19
QuoteOriginally posted by fevbusch Quote
I'm not sure at all, but I know this and that in my ist Dl manual they did mention what to due, but at the time I only used auto lenses and never folled with it. My suggestion would be to dig through the manual... actually you know give me twenty minutes and I'll download the manual and see if I can figure it out because what I am brigging up was buried in my K10D book and should be able to find it buried in the K100D manual. BRB
03-15-2007, 09:15 AM   #20
Page 188 of the manual states that you must trigger the optical DOF switch in order to get the correct settings in the camera for the f-stop chosen. Hope this helps and if you need anything don't be afraid to ask, just be very afraid lol.
03-15-2007, 11:50 PM   #21
skaktuss's Avatar
QuoteOriginally posted by codiac2600 Quote
I understand You, but I wanted to say that cameras light metering is not accurate. when You hit green (AE-L) button, camera chooses the shutter speed according to light, but i still have to increase it (1-2 clicks) to get normal non-underexposed picture.
example: i press AE-L (the same green b. on k10d), camera sets shutter speed to 1/80, but i have to set it to 1/60 or even 1/50, coz at 1/80 picture is too dark.
03-16-2007, 12:15 AM   #22
Mike Cash's Avatar
The amount of exposure adjustment required varies by lens. My modern lenses (A, M, DA, FA) require none on the K100D while my M42 lenses all require a +1.5 in order to get the correct exposure.
03-20-2007, 06:13 PM   #23
amateur6's Avatar
QuoteOriginally posted by Mike Cash Quote
Really naive question: I can guess why it's easier with "A" lenses, but why on earth would screwmount lenses be easier? I don't doubt you, I just can't begin to imagine why it would be true.
Thanks!
03-20-2007, 06:35 PM   #24
clm
Less button pushing
Most screw mount lenses have a switch that can be set so that the aperture stops down manually as the aperture ring is adjusted. It is not necessary to push the green/AE-L button before each shot. They can also be used this way in Av mode.
depth, k-mount, pentax 50mm, pentax lens, slr lens
Which lens is better Pentax 50mm 1:2 Rikenon 50mm F2.0 mesuper Troubleshooting and Beginner Help 16 06-14-2012 11:27 AM
Pentax SMCP-FA 50mm f/1.4 Lens or Sigma 50mm f/1.4 EX DC HSM? NicK10D Pentax DSLR Discussion 7 06-23-2010 06:21 AM
50mm FA 1.4, 18-55 AL II Kit Lens and 16-50mm DA* Pics jeremy_c Pentax SLR Lens Discussion 14 12-14-2008 06:20 PM
Fun to take pics with a kit lens again (Beware lots of pics) dsport Post Your Photos! 16 11-19-2008 06:56 AM
All times are GMT -7. The time now is 02:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
