Originally posted by fevbusch Eggarard, I did make the aperture ring setting in Custom and also the FL S setting.
I did shoot with camera set to AV mode out of habit, even though the aperture setting doesn't show in the info screen. Which mode would I have to be in for aperture ring to be manually used and effective
Freddy
Hi Freddy, you have to be in "M" mode, otherwise the lens won't stop down. Here is the proceedure I use to shoot manual with the DS, I don't know how different the K100D is but it should be relatively similar.
Pre shooting settings:
1) Enable aperture ring (you've already done this)
2) Hook the back wheel to Shutter speed when in "M" mode. This allows you to change shutter speed without having to remove your eye from the viewfinder.
3)Set the program wheel to "M"
Shooting:
1) Set the aperture via the aperture ring. Compose and focus in the normal manner.
2)Hit the AE-L button, you will hear an extended click as the mirror flips up briefly, the camera stops down the lens and meters the light thru the aperture you've selected. If it's a narrow aperture your viewfinder will get darker. (the button that does this may be different on the K100D I don't know) I'm sure the K100D posters can give you the correct button to push.
3) Check the shutter speed in the viewfinder, if it's OK then you can take your photo, if it's too high or too low for you adjust the aperture via the lens ring and repeat #2 above.
It sounds a lot more confusing than it actually is. You will pretty quickly get the "hang" of judging the light pretty quickly and setting an appropriate aperture. I've only been shooting with manual lenses since January and I'm very nearly as quick with them as I am a fully automatic lens. For me now it's compose, focus, AE-L button, check shutter speed, take picture. Takes 5X longer to type it than it does to do it.
NaCl(Hope that helps)H2O
