Unfortunately I don't have a long prime to compare it to, but my Sigma 150-500mm gives me all the cropping I need for birding with a 24Mpixel sensor.
Once you get out "so far" horizontally, depending on weather conditions etc., atmospheric distortion, especially over water, is often the over-riding factor.
Just to give an idea … on a "good day", shooting more or less vertically, an image of an over-flying jet (about 7 miles up) can reveal the registration letters under the wing, so the lens works, but shooting "across the pond" may well be limited to 300ft or less!
I've made similar enquiries in the past and replies from those who've owned (or still own) both a "bigma" and a Pentax 150-450mm suggest there's very little difference in image quality from either lens, suggesting that the "bigma" is up there with the best.
Do remember, with a long prime, actually finding your subject can be a problem. At least with a zoom you have the option to zoom out, locate your target, then zoom back in to frame and focus.
Having said that, a faster lens (f/5.6 or wider) will likely give you better tracking than the f/6.3 "bigma", but you'll be paying for the privilege!
As others will likely recommend, there's no substitute for getting closer
