With its conventional (i.e. unrounded) aperture blades, the HD FA 35 will produce starbursts, but due to the 6-bladed mechanism, they will be a far cry from the multi-pronged awesomeness of the smc DA Limiteds in that regard. Therefore, if it's starbursts you're after, check out the smc DAs 15, 21, and 35.
The two sample shots below were both done with the smc DA 15, but the 21 and 35 can be used to similar (starburst) effect. The smc DA Limiteds are no longer in production, but minty used copies crop up now and then on ebay and elsewhere.
Reason: Sample shots added.
