02-13-2009, 09:35 AM   #16
Igilligan
Guest
Hi Hin - a special request...
Hi Hin... nice test shots with your new 'replacement' attempt for the Lady Queen... Knowing that the hunt will go on... Let me please be the first in line for this lens when you dump her for the next Lady Queen imitator...
I am in full on lens buying crazy time again... And I have been trying to get a good copy of this one.
02-13-2009, 10:42 AM   #17
QuoteOriginally posted by MattKamineko Quote
Unfortunately, the aperture is stuck wide open, like lbam's lens. Am I likely to be able to fix this problem myself or is it a job for the shop? (and is it worth it)
It is definitely worth getting it fixed. The lens has a good resale value and even copies advertised on ebay as faulty fetch a fair bit (in the UK, £50 as opposed to in excess of £100 for a good copy).
It all depends on what is stopping the blades from moving, of course, as to whether you can do it yourself. But it is easy to open uip the lens (there are just three screws on the back, just make sure that you tape the aperture ring to the body first to prevent you from removing it and losing the detente ball and spring). The aperture ring couples with a lever that moves the blades - it may be just that someone opened it up out of interest and didn't put it back again right.
The best thing to do is search the manual focus forum - there are plenty of threads there about repairing Fleks. Or you could open it up, and take some pictures of the diaphragm and the levers that move it, and post them on the manual focus forum for advice.
Richard
02-14-2009, 09:02 PM   #18
Thanks the advice. I've had a look on that forum and I've had a go at cleaning the aperture.
It looks like there's some hidden friction and a spring problem which I can't fix, but I've at least got the blades to move. It looks like I can use stops in the range f/4-13 with it set to M (but heaven knows if the numbers still match up correctly) and it fully opens to f/2.4 on A. It'll do.
02-28-2009, 08:02 PM   #19
Nick Siebers's Avatar
I just got one of these (Thanks wallyb!) and so far am very impressed. I love the idea of a 1:2 macro normal lens for my K100d, and can't wait to tote it around once it finally gets nice outside. I'd love to know how it stacks up agaist the DA 35 macro optically, a quick test at f/4 in a sunlit room showed about equal performance with my DA 40mm, which I rate quite highly. No AF, of course, and you have to fiddle with an adapter, but it does cover "full frame"!
09-05-2009, 02:22 AM   #20
carl zeiss
I have just bid for one of those lenses. If I get it I'll let you know. Are you still using it? Mal Grosch UK
09-06-2009, 07:08 PM - 1 Like   #21
Sieg247's Avatar
You can follow this link to see some of my test shot with this lens.
Although minimum distance written on the lens is just 0.2m, but in fact, you can get closer, may be about 5cm i think
09-08-2009, 11:28 AM - 1 Like   #22
hinman's Avatar
QuoteOriginally posted by Mal Grosch Quote
It is a wonderful lens to have especially if you get a good copy. I have sold mine due to overlap with Pentax DA 35mm f/2.8 1:1 macro limited. While both lens in Fektogon 35mm and Pentax DA 35mm limited can't match up the status quote for the Pentax FA 31mm f/1.8. They are quite competent and they excel over the 31mm in terms of close up, easier on the wallet, comfort of heavy using day-to-day, and smaller size to bring along like a small 50mm.
Thanks,
Hin
09-08-2009, 04:19 PM   #23
georgweb's Avatar
Sieg said:
"Although minimum distance written on the lens is just 0.2m, but in fact, you can get closer, may be about 5cm i think"
Hey Sieg, beautiful photo you have posted on the other thread which shows one main attraction of this lens very well I think.
About the distances, these are always given relative to the film(sensor) plane. The Flek's front end on full macro position could be
around 15cm away from the sensor, plus 5cm and voilą there's the 20cm.
___________________________Heavy crop and some PP from the MC Flek 2.4/35 on K100D___________________________
Best, Georg (the other)
09-08-2009, 05:13 PM   #24
Angevinn's Avatar
This lens is one of my personal favorites. Very sharp with excellent color reproduction. The close focusing capabilities are icing on the cake. This is a B&W I took with this lens. I have some color shots somewhere.
Herman & Venus
Indiana University, Bloomington
09-08-2009, 05:53 PM   #25
Sieg247's Avatar
QuoteOriginally posted by georgweb Quote
you're right Georg, i said 5cm it meant 5cm from the object to the font element . By that, i believe it will very easy to imagine the can-do ability of the lens :ugh:
10-27-2009, 12:21 PM   #26
Ah, I was going to sell mine, but after some test shots decided no. Here's a few:
PENTAX K100D Super  Photo
11-05-2009, 09:12 PM   #27
Aw heck, I decided to sell mine after all. I had it on the marketplace here for a long time with no interest, so now it is on eBay. A goody copy, at a very good price, now!
Carl Zeiss Jena 35mm f2.4 Flektogon lens M42 screwmount - eBay (item 180426251028 end time Nov-07-09 17:00:03 PST)
11-06-2009, 08:10 AM   #28
I got my Flektogon 35mm a while ago but only took it out shooting last weekend on my *istD, and I have to say I'm really liking it. A couple of shots, both I seem to remember wide open at f2.4
100% crop from the last pic
11-06-2009, 08:41 AM   #29
QuoteOriginally posted by Indianadinos Quote
Hi Hinman,
I bought mine almost two years ago, when they were really cheap ...
I mostly agree with your impressions, this is a really nice lens (i really like the way its bokeh is rendered), it was my preferred 35mm until i got an SMC Takumar 35/2 ... The only point i have with it is that sometimes i would like a little less contrast (although this is quickly fixed when developing the raw files) ...
Best regards
Do you prefer the 35/2 takumar to the zeiss? I have the tak and have considered switching out, but I love the takumar between f2.8-f4...it's rendering is wonderful.
35mm, 40mm, carl zeiss jena, fa, focus, jena flektogon 35mm, k-mount, lens, pentax, pentax lens, slr lens, zeiss jena flektogon
Carl Zeiss Jena DDR Flektogon M42 2.8/20mm and K-x davidvandoren Pentax SLR Lens Discussion 18 08-26-2010 05:14 PM
For Sale - Sold: Carl Zeiss Jena MC Flektogon 35/2.4 (m42) AnttiM Sold Items 3 05-12-2009 09:25 AM
For Sale - Sold: Carl Zeiss Jena DDR Flektogon 35mm f/2.4 Close-focusing M42 Lens wallyb Sold Items 6 02-11-2009 10:29 PM
All times are GMT -7. The time now is 09:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
