Unfortunately, cropping when "birding" on a budget is about par for the course unless you're extremely patient (and well camouflaged) or have a good hide to work from.
The Kenko 2x (as with any 2x) reduces your exposure by two stops … not too bad on an f/2.8, starting to be a nuisance at f/4 and above, limits the autofocus functionality significantly!
If you can get close enough for the Pentax 1.4x vignette to be a nuisance, you probably don't need it … otherwise it might be your best bet … the Kenko 1.5x (which I use) might be a suitable alternative if you can find one.
Be aware that the Kenko converters are not recognised by the camera, so they're not fully compatible with the shake reduction, however, they do not cause a vignette on a full-frame camera
Good luck
