Originally posted by dms
I don't have the lens, but the performance/halo are not IMO excessive for an inexpensive lens at or near full open. (Or for an older fast expensive lens at/near wide open.) I suggest trying it at f/11. It may be fine there, and if so having two personalities is useful. I would treat it as positive, and use the lens in situation where the look would be desirable (e.g., many colorful lights/portraits/etc. where the softening/fog is attractive).
That's a good option to have at least some use for it. My disappointment is because I have quite good samples of Vivitar 75-200mm f4.5, which is almost as good as SMC-M 75-150mm f4 both wide open, and Vivitar 28-200mm f3.5-5.3. I was expecting similar results from the lens on question. But, alas! In fact, owning all these, I didn't really needed 70-210, just was seduced by a low price. I may keep it or try to sell this for parts then.
---------- Post added 05-18-22 at 02:05 AM ----------
Originally posted by othar
My lens does have a slightly hazy lens element inside (I haven't opened it yet, but I fear an element is separating).
Nevertheless does the lens still deliver in most situations.
Both images are taken at 210mm and f4.5 on my K-3
Othar, many thanks for posting these, it give some reference on how better example of this lense may perform. I guess, I just got some bad example.
---------- Post added 05-18-22 at 02:23 AM ----------
Spent about 4 hours today experimenting with the lens. First thing, I found an optical diagram for it, I put it here:
PSX_20220518_113317.jpg - Google Drive
Then checked correct sides for all glass elements. All were installed correctly. Tried reversing these, just for fun, but at no improvement, the only result was more fuzzy edges and not better central part (that would be interesting to achieve for zoom with pseudo bokeh effect, like monocular lens). Just a bad sample, who knows where it went wrong - glass quality, mechanical tolerances and decentering or other problems...
And yes, as suggested by dms, the lens is usable from f11, but this is a bit limited use, or to use fuzziness as an artistic effect.
I think, I will just give up. It was instructive to learn it's disassembly protocol, etc., perhaps may need this later for better sample. But, for practical use, there are better zooms of similar range and class in my drawer.
