Originally posted by dkpentax I see lots of lens reviews on the site, but why aren't there any real lens measurements for any lenses.
What we have here on Pentax forums are many reports on individual experience with K mount lenses and cameras out in the field, which in the end is where the gear we buy is intended to be used. Not everyone is a formally trained optical testing technician here*.
Originally posted by dkpentax im interested in how sharp lenses are, not vague pictures of test charts.
You're interested in numbers: I get that. But MTF charts can only tell you so much about a lens. MTF charts cannot tell you anything about flare handling characteristics, colour reproduction, physical aspects of a lenses operation - all of which are important variables to take account of when making a purchasing decision.
Originally posted by dkpentax isn't it possible to determine the lines per inch that the full size K-1 and APS-C K-3 sensors can achieve, then measure every lens of some kind of lens bench, and determine the real resolving power at all the different combinations of aperture and position across the image plane.
Optical benches like the ones I use are capable of going far beyond any current cameras resolution capabilities, however doing this is
extremely time consuming and demanding on technique, and mostly a waste of time as cameras are going to take decades to capture 1 gigapixel of resolution in a single shot. Most MTF's from manufacturers are synthetic: calculated from predicted values and hardly representative of actual performance. Only a handful of manufacturers publish
actual MTF data from their lenses AFIK.
One of the biggest problems with optical testing is that you have to obtain a perfect, flawless copy of the lens in question - depending on manufacturer** this can be nearly impossible without divine intervention. I have been fortunate to be in contact with manufacturers and receive copies of lenses certified by the company itself to be free of defects - but this was an
exceptional case, and is far from the norm. Sample variation can be difficult to assess with some lenses as high performance lenses can be very expensive to acquire. With some lenses I can borrow copies from friends this allows me to test multiple copies without the expense of getting copies of my own to test, this lets me obtain an overview of how great the sample variation with a particular lens can be between lens manufacturers.
* I am though. I will point out there are some user reports here that, for reasons of ignorance and ineptitude... and perhaps spite, seem to trash lenses and assign scores of 1 in every category, these reports are equally useless as those that assign perfect 10 in every category. I have tested many lenses over the decades there are only a handful I'd consider to be deserving of a 9 across the board.
** All I'm going to say is that one of the
egregious offenders in the lens copy lottery over the years has a name beginning with an S.
