Originally posted by dkpentax I tried staring through the 28mm while I focused and couldn't see anything moving around, anyone know which elements are supposed to move?
The only way to
truly ascertain the movement of optical elements in a lens is by pulling it apart and examining the function of the internal cams/helicoids and any elements in a fixed position. I will point out that internally focusing lenses are distinct from those that incorporate floating elements, as a floating elements are often used to correct aberrations/extend focal range while a focusing group used in IF lenses is designed to move the focal plane in its entirely with the elements on either side of the focusing group remaining in a static position*.
I think the first lens to use floating elements was a 50mm f/2 constructed by Meyer Görlitz in 1950's - it was marketed as a macro/standard lens, in which the floating group could be switched to an alternate position and this optical configuration allowed for enhanced close focusing capability.
* Though in the case of some IF zoom lenses I have observed some movement of front or rear optical groups and sometimes both front and rear groups moved simultaneously with the focusing group remaining static - an example of this is the Sigma 8-16mm f/4.5-5.6 DC
