I have a SMC Pentax-M 28mm f2.8 which is mechanically good but riddled with fungus. I've managed to get the front apart and roughly cleaned the front elements. I will need to re-do this properly. I'm stuck at dissembling the rear elements. It appears there are two variants of this lens:
SMC Pentax-M 28mm F2.8 Reviews - M Prime Lenses - Pentax Lens Reviews & Lens Database
I've searched on line for this lens and similar, and of course, I can only find information on people disassembling the other variant. On the other variant you can simply put a lens spanner on the rear lens assembly to unscrew it. However, on mine that does not work. There appears to be a ring you can unscrew, but it is hidden under a wider flange that blocks a regular lens spanner. Pictures attached.
Has anyone any experience with this type of assembly? Before I do something that potentially causes damage I thought I would ask? As I see it my options are:
1. Grab the sharp flange with a rubber glove and apply an unreasonable amount of force (this will hurt, the flange is sharp!)
2. Place the tip of a small screwdriver into the notch in the ring just below the flange and gently tap it. This will likely cause some minor damage to the notch.
3. Less favoured, drill a couple of small holes in the flange, or file a couple of notches and try a lens spanner on it.
Thoughts?
Incidentally, I bought some JIS screwdrivers to remove the bayonet mount. I'm very surprised that I did not strip the screws, snap their heads off or destroy the screwdriver bit. It took a lot of force to undo them.
