12-16-2008, 07:33 PM   #1
Big Dave's Avatar
SR using zoom lenses
Hello,
Does anyone know how the focal lenght information is handled by the DSLR when using a F or later zoom? Does the data get updated as the lenses are zoomed or does SR use a mid range value? The reason that I am asking this is that I just got an "A"zoom and was surpised to find out that it didn't transmit the data. How do you use manual zooms? Do you reset the focal lenght after zooming, use a mid range setting or turn off SR? I had been using the mid range approach on the shorter range manual zooms. This hasn't caused any issues for me. What do you guys do in this case? It seems like this is a good case for using prime lenses of the manual type as oposed to manual or even "A" type zooms.
Regards, Dave
12-16-2008, 08:01 PM   #2
I have a manual zoom (Tamron Adaptall2 80-200mm f/2.8 with a PK adapter), and I usually set the shake reduction to 200mm and turn it off when I zoom out, but it depends on the situation.
Oh, I almost forgot: I was under the impression that the shake reduction value was updated as you zoomed the lens with new zooms. The exif information shows what the zoom level is, so the camera obviously "knows" what it is.
12-16-2008, 08:12 PM   #3
Big Dave's Avatar
CF,
Thats a good point. So using the mid range setting may not be such a great idea. I have a 16-45mm DA arriving this week and I think that it is going to see a lot of action.
Dave
QuoteOriginally posted by CFWhitman Quote
12-16-2008, 09:05 PM   #4
Stratman's Avatar
I have a Takumar F Zoom 28-80 mm, and the exif shows the focal length, so I would imagine that SR works like it does with the newer DA lenses
12-17-2008, 10:04 AM   #5
F and later transmits the focal length, so you'll be fine.
12-17-2008, 12:01 PM   #6
alohadave's Avatar
QuoteOriginally posted by Big Dave Quote
CF,
Dave
The 16-45 won't be an issues since the camera communicates with the lens. You can't even set anything for SR with current lenses.
data, k-mount, lenght, lenses, pentax lens, range, slr lens, sr, type
About zoom lenses with variable aperture Vranx Pentax SLR Lens Discussion 15 07-24-2010 07:43 PM
What is the Top Ten Zoom Lenses? rodfs Pentax SLR Lens Discussion 12 04-03-2010 07:20 PM
1.4x or 2.0x Teleconverters with Zoom Lenses d-sr Pentax SLR Lens Discussion 11 08-20-2007 10:53 AM
What (zoom) lenses would you like to see? CSpronken Pentax SLR Lens Discussion 20 06-05-2007 01:22 PM
M Zoom lenses on K100D? jsundin Pentax SLR Lens Discussion 2 10-20-2006 07:37 PM
All times are GMT -7. The time now is 01:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
