Originally posted by GUB Short answer haze is bad.
Finger print = Bad - PentaxForums.com
And if it is rainbow colored then it likely would spread further.
If that is the haze around the edges then once you stop down a couple of stops it should be fine. But is that what you want from your lens.
An interesting read, i'm even more curious about the (now dead) link that was pointing to cleaning the lens too much being bad!
I will ask the seller about the haze and if it's the whole crescent in that photo.
Generally, if it means stopping down and it won't be an easy thing to fix, maybe a pass on the lens is a better choice.
Tough to know, especially as a lot of older lenses aren't in the best condition being that they're getting quite old... hmmmmm....
