07-02-2022, 07:03 PM   #1
Do F lenses bang to stop ?
I came across the F 28-80mm and used on my digital camera, it was quite noisy in focusing and bang to stop at both ends, unlike modern shaft drive lenses that stop smoothly, wonder if that was the design or the film lenses not working properly on digital camera ? here's an example on Youtube, it seems all F lenses worked the same.
07-02-2022, 07:17 PM   #2
retired sw engineer
reh321's Avatar
QuoteOriginally posted by lotech Quote
https://www.youtube.com/watch?v=_BvGx6uUHA4
I switched to Canon because I loved their EF/usm lenses - better in my view than what Pentax was doing for AF {‘F’ lenses}. In recent years, I purchased a FA 28-105mm lens so I could set aperture at the lens for my K-30 {which now suffers from “Dark Image Syndrome}, so I guess I’ve never owned a ‘F’ lens, but l still doubt if Pentax’s first attempt at AF was up to their usual standards. In my case, the screw drive makes more noise than the in-lens motors do, but nothing like you describe. Back before I got a 55-300mm PLM lens, my wife used to complain about the noise made by DA 55-300mm focusing, but frankly, the lens I had then was no noiser than the ‘FA’ lens is.
07-02-2022, 07:33 PM   #3
QuoteOriginally posted by reh321 Quote
I got the DA 55-300mm non PLM too, and it produced higher pitch noise than the old F, but did not bang to stop. If those lenses can be made using internal focus (faster focus) then the noise will not be too much of a thing,
07-02-2022, 07:36 PM   #4
luftfluss's Avatar
I've owned multiple copies of the F 35-70 and F 70-210, and yes, both have rather violent AF action and "bang" when focus is attained.
07-02-2022, 07:57 PM   #5
sbc
I used to own a few F lenses for my SFXn and Z-1. Yes they have rather 'violent' AF. A little disconcerting if you are new to them.
07-02-2022, 08:08 PM   #6
QuoteOriginally posted by sbc Quote
Yes that troubled me a bit, whether it was 'normal' by design or a flaw are not ideal.
07-03-2022, 04:14 AM   #7
sergysergy's Avatar
completely normal
07-03-2022, 06:23 AM - 1 Like   #8
AfterPentax Mark II's Avatar
Yes, that is a familiar sound. Not only do they bang, they are also quite fast AF-lenses. That is what I noticed on my SFX's. And it did not bother me then and it does not bother me now. Simply because of the great the results they deliver. Take the F 50mm F1.4 and you will not believe your eyes if you see the result.
07-03-2022, 12:35 PM   #9
It has always seemed to me that F lenses were the most obviously designed around a set of constraints the engineers didn't really know how to address gracefully.
In comparison to the first-generation 35-70 f2.8 AF lens on the ME-F, the F lenses are worlds faster, but it is obvious from everything about them they were designed around focusing fast with the camera motor.
They are generally rotten for manual focusing, with sloppy feel, but they work well in autofocus.
And all of the ones I have used have "banged" like that...
I still have a 50 f1.7, 35-70, and 70-210 in pretty common rotation...
-Eric
07-04-2022, 05:30 AM   #10
bdery's Avatar
Indeed, the lenses bang. FA lenses do the same, for the record. I remember being surprised by the torque and hard stops of the FA 100-300 F4.7. It's fine once you're used to it.
07-04-2022, 06:27 AM   #11
retired sw engineer
reh321's Avatar
My FA doesn’t do this on my K-30. Maybe the particular camera makes a difference??
07-04-2022, 01:31 PM   #12
MarkJerling's Avatar
I have a fair number of FA lenses. Interestingly, most "bang" on my old film SLRs and also on my (now my daughter's) K5. On the K-1ii, the focussing is far less violent and more precise.
So, I also think it's (partly) body dependent.
07-05-2022, 05:30 AM   #13
bdery's Avatar
Which FA?
07-05-2022, 05:38 AM   #14
retired sw engineer
reh321's Avatar
Which FA?
28-105mm
07-06-2022, 05:31 AM   #15
bdery's Avatar
28-105mm
A more recent model I believe. Seeing as it almost certainly has a hard stop, it comes to it slowly instead of full head-on?
bang, camera, k-mount, lenses, lenses bang, pentax lens, slr lens
Best "bang for buck" lenses (K-5) philodragon Pentax SLR Lens Discussion 67 01-22-2016 10:46 AM
Best bang for the buck in telephoto lenses? pentaxmz Pentax SLR Lens Discussion 20 08-13-2014 07:04 AM
People bang-bang and flew by by zztopd Post Your Photos! 8 02-08-2014 03:52 PM
Sports Bang Bang bluestringer Post Your Photos! 2 02-03-2013 07:42 PM
The Bang Bang Club richard balonglong Photographic Technique 3 08-15-2011 01:39 PM
All times are GMT -7. The time now is 09:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
