Originally posted by GUB Looks like half plate size is rather variable. I had been going with 4.75 x 6.5 which is the size of some I have here.
Plus using 8 1/2 inch lens as a wide angle can be out to 6 1/2 x 8 1/2 as per a 1900s advert. Of course that depends on the individual lens capability which is too hard to work out without
actually pre-constructing a body.
So I have gone with 6 x 8 as a primary target.
If I go too small I will start to lose the overall large format effect.
If I have gone too big (Target) then I can always lengthen my digital lens focal length to perhaps 35 mm.
I think my maths is coming out similar to yours - I worked my digital lens distance from fov to get 200mm (8 inch).
One thing that may be insurmountable is getting enough shift with a very limited amount of extension available to me.
But I am unsure of my maths - need a formula!
According to my calculations with a target 200mm from lens centre I need only 3.6 mm extension from infinity. (28mm)
It is going to be hard to keep a shift adapter that small.
At least the K30 has some composition adjust to help.
Here is a screenshot of what I am envisioning. In both cases back of lens is about at outer edge of lens board. obviously digital on top.
The old lens would be mounted inside a K mount bellows extension attached to the lens board. This should give me some focus adjustment before vignetting.
Hmmm... to view a 6x8 target with a K-30 sensor (15.6mm x 23.7mm), the magnification is 0.102X (assuming you want the entire 6x8 image to be captured uncropped). That puts the lens center at about 302mm from the target, much farther than the front standard. You might need a wider-angle lens on the digital camera if you are using a wide angle lens on the view camera.
As for the amount of shift, it's just the magnification ratio multiplied by the total view-camera-center-to-digital-camera-center offset.
Note: you might benefit from testing the focus, field of view, and distances for both your view camera lens and your proposed K-30 setup. A table or stool next to a window can become an ersatz optical bench and some bits of cardboard, graph paper, and a ruler can help you find the plane of focus for the view camera lens and check its image circle size to see how big a view you can get. You can check the K-30 + lens with your proposed 6"x8" target by setting them on a table, too.
Reason: Added note
